Too say the least I’m stumped. I have a 2005 F250 6.0 with 170k, lately it’s inherited a some what of a “stutter”. It ran flawlessly, but recently, directly after an oil change this “stutter” came on. Once it begins to warm up it runs a little better but still not like it used to. My icp duty cycle and injection pressure were reading lower than normal, I replaced both Ipr and icp with motorcraft parts. The Ipr screen had one pin hole tear and a few flakes of metal. After replacing both the issue still stands. Next on the agenda is to check both fuel and oil pressure to try to rule out either hpop or fuel pump. The ficm, is getting 48v at main, and 13.5v at internal. Has anyone else run into a similar problem? Any input would be greatly appreciated
thank you.
Probably not what you want to hear, but you need to get ForScan or ForScan Light as a scan tool (downloads), and the appropriate OBDII adapter for your device. The SCT absolutely will not thoroughly pull codes. ForScan will.
Also, you may not actually be getting actual OEM parts. I am skeptical of the parts from the big chain auto parts stores.
I will look into getting ForScan, I know the SCT isn’t the best for reading codes (hence why it isn’t showing any) but for reading gauges it has worked fairly well up to now.
Both parts can in motorcraft packages so I didn’t second guess it. The first IPR valve I tried was from GB remanufacturing, I went the cheaper route due to budgeting reasons but it was a dud. So I choked it up and went with their motorcraft option.
At KOEO MAP-13.92 psi, EBP- 48.01 psi, BARO- 13.93 psi
At idle MAP-14.24 psi, EBP- 60.41 psi, BARO- 13.93 psi
also I unplugged the EBP and ICP and went around the block and it’s still there. Would you suggest one at a time?
That EBP is way high for idle, but again - SCT is known to report wrong values. At idle, the EBP should only be a few psi above MAP and Baro.
I asked for KOEO though: "Key-On-engine-Off"
Probably don't need to unplug them one at a time.
Inspect MAP sensor hose for leaks or holes or tears or plugging. Make sure the nipple on the intake manifold that the MAP sensor hose attaches to is clear (not plugged).
The first one is KOEO, seconds at idle.
I’ll inspect the MAP later tonight and will have to get back to you.
Sorry, I missed that I guess. That EBP value is way off. You need the ForScan, or Torque Pro reading on that. Also need one or the other of them for codes.
So I got an icp low circuit along with a IAT high input. The map sensor has some oil residue on the engine side of the tube, but sensor side and connectors look fine.
