Injector/ fuel upgrade
Old Nov 13, 2023 | 08:56 AM
Calebcuster's Avatar
Calebcuster
Hey guys, my injectors are on their way out so I am planning on getting injectors in the near future. I want to push good power and ideally I’d like to have enough power that it is considered fast, at least for a 7.3. I do not do a lot of heavy towing but here and there I do. I’m looking for the best injectors, fuel system, hoop, that would fit my needs, I don’t need specifics but just trying to get an idea of what to go for. Thanks!
Old Nov 13, 2023 | 09:17 AM
knottyrope's Avatar
knottyrope
Stock, this thing is a beast. IMO
shaker or auto?
Get your Fuel system working well
Eliminate all boost leaks, oil leaks and drive line vibrations.
Then do supporting mods like HPOP, efuel and Intercooler.
A chip can give you 50 HP, that might be the boost you need.
Injectors can be fun to pick and many here have their opinions.
Drop in KC turbo kit if you need more air or go the T4 route deepening on money and towing performance
Old Nov 13, 2023 | 02:24 PM
Calebcuster
I have it stick with a ts chip right now and would like more power, I’m going to upgrade my injectors, I guess the question is how big is too big?
Old Nov 13, 2023 | 02:29 PM
Calebcuster
It’s an automatic, my ts allegedly gives it 120 extra hp but I have my doubts, it hardly smokes at all but will chirp the tires at a stop and do burnouts a lot more easy.
Old Nov 13, 2023 | 02:49 PM
knottyrope's Avatar
knottyrope
Get some 250/100 injectors and have some fun with them
https://www.rosewooddieselshop.com/p...injectors.html
Old Nov 13, 2023 | 07:47 PM
7.3 forever's Avatar
7.3 forever
Without spending a ton I’d highly recommend some 160/30 or 200/30 from Jim rosewood. Honestly I’ve installed 160/30 in couple trucks without tuning they run great.
Old Nov 14, 2023 | 08:32 AM
ESwift's Avatar
ESwift
CNCFAB
A fun useable setup that I prefer is a set of 200/30 injectors, fuel system, upgraded hpop. KC300X stage 1 or 2 turbo and an intercooler, depending on what the truck is used for, gearing/tire size, and elevation.
Prolly gonna need a built transmission at some point, or if a manual a good clutch.
Old Nov 14, 2023 | 08:35 AM
ESwift's Avatar
ESwift
CNCFAB
If you want a more budget friendly option. 160/0, stage 1 hpop, KC300X stage 1 or the KC stock plus, e-fuel, or a good healthy stock fuel system.
You will want bellowed up pipes and othe misc items for just about any setup you choose.
Old Nov 14, 2023 | 10:56 AM
Calebcuster
Okay thank you for the input! I’m okay with spending a little money, I don’t wanna blow my whole bank account out but I definitely want to put some power to it.
Old Nov 14, 2023 | 11:31 AM
Hit Man X's Avatar
Hit Man X
What all performance stuff do you have now?
Efuel makes power on these. You can reflash that TS but probably better off selling it and putting that profit towards a Hydra setup.
I would agree you probably have uppipe leaks unless they have been replaced.
Old Nov 14, 2023 | 11:54 AM
Winter2's Avatar
Winter2
Add a second fuel filter upstream of the factory fuel filter. Many many posts on how to do this. The aftermarket kits also allow for using much larger fuel filters. For injectors the Bosch are usually the best. Replace the injector wires as well if any are faulty (check Ohm readings).
Old Nov 14, 2023 | 12:44 PM
Calebcuster
I just have a ts chip I got from a friend but I think it is not the correct pcm code because it doesn’t feel like it adds the listed power, otherwise I only have an intake, which doesn’t really count, the rest of the motor is stock. I only got the ts chip as a temporary power adder until I do injectors and everything, I plan on getting a hydra, fuel system, injectors, hpop, and whatever else you guys would recommend to do it the right way, I want to make sure I don’t just throw it together in hopes of making more power and skip things that may fail or cause it not to work right. I want to do everything right and the most cost efficient way I can.
Old Nov 14, 2023 | 01:27 PM
Hit Man X's Avatar
Hit Man X
Downpipe, leak free manifolds/uppipes, and efuel.
Those will add solid power gains for about $1500.
Old Nov 14, 2023 | 09:09 PM
z31freakify's Avatar
z31freakify
Stock injectors with a "hot" tune are only good for like 50WHP, then you are limited by the stock fuel system,
Not knowing what tranny you have or your budget, I would invest on supporting mods before dumping any dinero into power adders.
-E-fuel
-Intercooler
-Bellow up pipes (if planning on staying with the stock turbo or a drop in aftermarket one)
-HPOP
-Down pipe or turbo back system (stock exhaust flows plenty minus kitty and down pipe)
-in tank mods
-intake (6637 is cheap)
-Tranny? If auto a good low stall triple disc converter will help (cheap) but not knowing your budget and the type of build this will be the $$$
if manual a good clutch is about all you can do to it.
Once you do all the above then we can start talking about power adders.
1ole4d
Feb 3, 2017 07:07 AM
MikeDehner
1978 - 1996 Big Bronco
Jun 28, 2010 07:51 PM
fordman1954
Apr 5, 2007 05:16 PM
GammaDriver
1997 - 2003 F150
Jan 26, 2007 08:35 PM
ecsmith0624
Nov 21, 2003 07:51 PM
