1986 F150 Clutch Adjustment????
slave
that is good to know, thanks, I read it again in my haynes manual but I will go with the hands on experience u got. Is there a seal or something where the hose goes onto the slave cylinder, mine is wet?
I've posted this question under the "clutch/drivetrain" section but I thought I should post it here as well. I just installed a new (Fenco Dynapak ) 10 inch clutch,p.plate,t/o bearing in a 1986 F150 with a 4.9L. Now the trans will not go into gear with the motor running. It acts like the wrong t/o bearing but the parts place assures me that all the parts that I installed were correct. I was told to adjust the free play by one mechanic and a Ford dealership told me that a hydraulic clutch has no adjustment. The slave cyl andm/c are working fine. I have checked everything that I can think of short of tearing it all apart again...which I was hoping I would not have to do.Any body have any ideas?????
If I need to buy a whole new clutch kit where can I be sure to get one with the gauranteed proper throw out bearing.???.
I am pretty certain now it is not the throw out bearing. Now I have a lot of play in my clutch pedal that got gradually worse till it won't shift at all now while running. I replaced the bushing on the rod going thru the firewall to hydraulics. Now I am stumped on how to tighten up the play in my pedal.??
Is your fluid level good? When you check the level, stick your finger down in the fluid. They have a rubber cap that fits up in the lid of the reservoir, and sometimes that cap sticks to the top of the reservoir, you can't really see it. And the you put fluid in it to top it off, not realizing the real fluid is underneath the rubber cap, and you are running out of fluid underneath. It's happened to me and several other people I know.
You saved me a lot of time and money Franklin2.
Thanks, I double checked sticking my finger all the way down and hit the bottom of the rubber cup. Reaccordianed it and refilled , pumped the clutch a bunch and problem solved. Thank you very much for that advice. I let it ride while I was waiting for a floor shift kit and after installing went back to the pedal problem focusing on master cylinder.
A lot of them do not have any adjustment. You might have a aftermarket unit, I have heard some of them come with adjustable pushrods.
joezzz
Jan 1, 2017 11:13 AM
red97stroker
40
Sep 19, 2010 12:16 PM
