1990 f150 302. Manual transmission long box dual tanks
hello, my f 150 is ready for a new front fuel module ..the rear one is working fine..gauge ..pump one way valve all seem ok.
but the front pump has the brass float and gauge does not work.. , plus. the front check valve is not 100% and the rear tank slowly fills the front one…then when the front one is about 1/2 full ..I use it and use the gas to keep it from filling from the rear one.
I have located, 2 companies selling fuel modules that I believe are the correct ones.
has anyone any thoughts on which one is best..
im in Vancouver..so the one for sale in cdn dollars is 30% cheaper than if if it was in usd
