Sponsored by: Auxito
Inner CV joint bolts? Help!
Old Nov 4, 2023 | 01:20 AM
Richekl's Avatar
Richekl
8th Gear
I need to replace the inner bolts that hold the CV joint to the axle on a 1999 F150. I can't find them in a Google search or on Amazon or Ebay. Can't find a part number.
Can anyone tell me how to get replacement bolts?
Old Nov 4, 2023 | 06:31 AM
manicmechanic007's Avatar
manicmechanic007
The junkyard is probably the easiest place
Old Nov 4, 2023 | 06:40 AM
Richekl's Avatar
Richekl
8th Gear
I was really hoping to be able to put new ones in, and definitely not have to try to break any loose at a junk yard. But thanks for the suggestion.
Old Nov 4, 2023 | 06:50 AM
manicmechanic007
You should be able to find them laying on the ground at the junkyard
New, I would hit the dealer for a part number then search Ebay when the dealer says they are obsolete
Old Nov 4, 2023 | 07:01 AM
Richekl's Avatar
Richekl
8th Gear
That's an idea. Thank you.
If anyone here knows the part number please let me know. Thank you.
Old Nov 5, 2023 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
are they 12mm x 12 point heads ?? Same bolt that used on drive shaft yokes on Ford trucks ? ..... you might google "half shaft to axle bolts"..
Groundpounder0331
13
Jun 23, 2025 02:18 PM
enikolich
Oct 15, 2017 11:58 AM
fabieber
Nov 14, 2015 10:18 PM
sc93f
May 4, 2006 08:35 PM
idaho211
Offroad & 4x4
Mar 26, 2005 12:56 PM
