The driver side windshield washer nozzle sprays high, clear of the windshield. Can it be aimed by levering with a needle, shimming the base or is it junk once misaligned?
take it off, soak it in some vinegar, blow dry with air and see if it works. they are not adjustable... if they are you will see that the nozzle is metal on the inside and put a paper clip in it and move it as needed. only one way to find out!
my nozzles were crap, i cleaned them for 5 minutes in soapy water in my ultrasonic cleaner, worked perfect. had one spraying LOW and the other forked in half missing completely.
use rain-x wiper fluid. you will thank me later if you have not yet done so
Thanks! It puts out a healthy stream, just not where it’s supposed to go. I’ll take a closer look at the attachment. Maybe it wasn’t put on correctly. Give it the cleaning you suggested while it’s out.
