I'm new to Forscan and have a question regarding adjusting the tire size to calibrate the speedometer. I have a 24 350 Platinum with 37" tires. I followed the spreadsheet supplied here and adjusted the tires size to 2781mm, which puts the spedo spot on. I think stock it was set to 2650ish. This is literally the only thing that I adjusted. Upon writing the new tire size value I found that now the 'check engine' light is on and also the 'service engine soon' light as well as a service engine soon and check 4x4 warning at start up.
Is there a way to bypass the warning lights in order to maintain the correct tire size? I'm assuming that the new value is out of Ford's spec, thus triggering the lights.
