NO START, NO CRANK AND NO START!
Old Oct 31, 2023 | 01:26 AM
Alexis Garcia's Avatar
Alexis Garcia
Would my problem be my starter?
Battery levels on my truck were good, hooked up my portable jump starters and still no crank. When I turn key over doesn’t crank and doesn’t even click either
This has led to me being that the starter has left the chat. Recently I’ve notice hearing the starter sound a bit slow or weak when cranking it for the first time of the day
Lights on my dash are good, no flicker or anything
Old Oct 31, 2023 | 03:23 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Try pulling the shift lever up to the left before cranking, or put the trans selector in neutral. Kinda sounds like the neutral start switch is messed up.
Or just hit the starter with a big hammer before trying to start. A failing starter will beg for some BDSM before finally crapping out.
Also what year? Could jump the starter solenoid on the firewall.
Old Oct 31, 2023 | 03:56 AM
udsuth78's Avatar
udsuth78
If the hammer and ball gag don't work you can check the battery cables and terminal connectors too. Loose and/or corroded power and ground connections are probably the #1 cause of no crank worldwide.
Old Oct 31, 2023 | 04:00 AM
udsuth78's Avatar
udsuth78
This very nearly caused a legitimate spit take. Well done sir.
Old Nov 7, 2023 | 09:22 AM
Nascenta's Avatar
Nascenta
4wd Low
My solution
I was working on the hpop and it wouldn't crank. The dash lights would go on but when I turned the key to engage the starter.. nothing. Turns out I didn't completely engage a 12 pin connector above the motor that was to the left of center, kind of above and behind the transmission dip stick (this is in a e-450). Prior to this I jumped the starter so I knew the starter was working and getting juice. This is done from the starter relay (on fender) or the connector that goes into the transmission.
Good luck, you'll figure it out.
El Campo
Feb 13, 2019 08:08 PM
BlueOval351
Apr 18, 2015 07:06 PM
lifted77f250
Mar 26, 2011 04:47 PM
GT V10
Nov 6, 2009 01:09 PM
allisonmo2
Mar 3, 2009 05:04 PM
