P0743 code but it still works
Old Oct 30, 2023 | 01:46 PM
Rackovanz's Avatar
Rackovanz
4th Gear
Hey everyone,
I am getting a p0743 code and a check engine light. The TCC still locks up but only once the 4r100 gets to 120 degrees. Everything else runs really well, the transmission shifts fine. I am going to start looking through wiring but was curious if anyone had some insight.
Zachary
Old Oct 31, 2023 | 09:19 PM
Rackovanz's Avatar
Rackovanz
4th Gear
Originally Posted by Rackovanz
Hey everyone,
Zachary
I also have code p1744
Old Nov 7, 2023 | 11:42 AM
Rackovanz's Avatar
Rackovanz
4th Gear
Any thoughts?
Old Nov 7, 2023 | 02:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The P0743 code indicates an electrical circuit problem. It could be a wiring issue, a bad connector, or a bad solenoid. Since you say it is still locking the converter, it appears to be an intermittent issue. The P1744 code set because of the electrical issue.
Looking through the wiring is just wasting time. You need to check the wiring electrically to find a problem.
Old Nov 7, 2023 | 08:10 PM
Rackovanz's Avatar
Rackovanz
4th Gear
mark thank you very much for the advice, can you point to any reference materials for the electrical checks for the wiring?
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
chzuck
2004 - 2008 F150
23
Sep 21, 2022 06:25 PM
55F250
General Automotive Discussion
Sep 5, 2009 02:14 AM
dkrobson
1978 - 1996 Big Bronco
Jul 29, 2008 04:41 PM
That_Guy
Jan 2, 2008 06:45 PM
