351 efi
Old Oct 29, 2023 | 03:44 PM
kenny nunez's Avatar
kenny nunez
Question 351 efi
Did any 351s up to 96 have mass air fuel injection?
Old Oct 29, 2023 | 04:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes. For California emissions
Old Oct 29, 2023 | 08:10 PM
Blurry94's Avatar
Blurry94
And non-CA trucks as well.
Old Oct 29, 2023 | 08:40 PM
AuroraGirl's Avatar
AuroraGirl
I thought non-CA got speed density. I guess maybe that depends on if we are talking f150 vs f250 vs f350?
Old Oct 30, 2023 | 05:13 AM
torq'ta 5 8's Avatar
torq'ta 5 8
yeap, your rite!
Old Oct 30, 2023 | 07:52 AM
Scndsin's Avatar
Scndsin
There were OBDI MAF 5.8 in 95, possibly 94.
In Cali & some parts of the N. East/New England.
Old Oct 30, 2023 | 09:00 AM
1Butcher's Avatar
1Butcher
I own a 1995 F250 5.8L with factory MAF. California emissions.
Old Oct 30, 2023 | 09:05 AM
kenny nunez
Question Obd1 ca.
Does your engine have a knock sensor, if so where is it located?
Old Oct 30, 2023 | 09:09 AM
1Butcher's Avatar
1Butcher
No. No knock sensor.
Don't trust me but I do not believe any 351W/5.8L have a knock sensor from the factory. Only the 5.0L and probably the Mustangs only.
Again, don't trust me what so ever.
Old Oct 30, 2023 | 09:56 AM
Conanski's Avatar
Conanski
There was no knock sensor on any EFI 5.8.
Old Oct 30, 2023 | 10:03 AM
kenny nunez
Smile Knock sensor
Many thanks guys, I am in the process of rebuilding a 351 from a 250 that was speed density. The 150 I have was a 302 with Mass air. I am going to use the 302 harness and control system on the 351. I will just leave the knock sensor disconnected.
Old Oct 30, 2023 | 10:05 AM
1Butcher's Avatar
1Butcher
If I was in your shoes, I would look into using the knock sensor. At least look into the fact it is a benefit or not. You will need to figure out the tuning for the control module if you are going to up the size of the engine.
Old Oct 30, 2023 | 12:04 PM
manicmechanic007's Avatar
manicmechanic007
I sure like that about don't trust me whatsoever, 1Butcher
I should add that disclaimer to all of mine
Ford made so many different models for low altitude and such markets that it is hard to say absolutely what they made specifically this or that market
TX for instance
Most cars had a MAF by 92-94 and the trucks just a little later IIRR
Old Oct 30, 2023 | 02:42 PM
kenny nunez
Knock sensor
There is a 7/16” 13 threaded hole on the right rear of the block, the knock sensor is 1/2” 13. I can make an adapter on my lathe or drill and tap the rear corner of the intake manifold over the rear water passage of the head.
So far my biggest problem is locating a “Y” pipe for the 351. Every number I have found so far is not available. The JY did not have the pipe from the doner truck. If any one close to me has a “Y” pipe let me know.
Old Oct 30, 2023 | 03:31 PM
Scndsin's Avatar
Scndsin
I'm very interested in your 5.8 knock adaption.
I can utilize one with the pimpx if I make a place to screw one in.
Problem is, there's no place central to listen equidistant to both heads.
Does it matter?
