Transmission modulator
Old Oct 27, 2023 | 01:35 PM
fordforlife62's Avatar
fordforlife62
8th Gear
What is the right color stripe for my 88 F250 c6 modulator? Thanks
Old Oct 27, 2023 | 02:18 PM
superkonr's Avatar
superkonr
Black stripe
Old Oct 27, 2023 | 04:10 PM
tjc transport's Avatar
tjc transport
i ain't rite
depends on your location. black stripe for sea level. green stripe for the mountains of colorado.
Old Oct 27, 2023 | 07:34 PM
superkonr's Avatar
superkonr
dont forget that if its raining out you have to switch to the purple stripe before you can start the truck.
Old Oct 27, 2023 | 09:42 PM
fordforlife62
8th Gear
Come on man, really? That’s the best you can do? Somebody help me out. Please.
Old Oct 28, 2023 | 04:34 AM
superkonr's Avatar
superkonr
All trucks and vans take the black stripe modulator. The black stripe gives the firmest shift from the factory which is necessary in a heavy vehicle. The other colors are for passenger cars and give a softer shifts. It's dependent on the weight and gear ratio of the vehicle but trucks take the black stripe.
Old Oct 28, 2023 | 07:55 AM
fordforlife62
8th Gear
Thanks for the info. I’ll get one ordered today. If it doesn’t fix early shifting, 1st to 2nd around 7-8 and 2nd to 3rd around 18-20 any thoughts on where to go next? I also have no kick down.
Old Oct 28, 2023 | 10:36 AM
superkonr's Avatar
superkonr
The kickdown just quickens the 3-2 downshift if you floor it. It won't make it shift early. Put a black stripe in it and we'll go from there, usually some previous genius just put the wrong replacement in at some point. Catalogs aren't always clear on the correct applications for those modulators. The colored modulators in a full sized truck will make it shift early and the shifts will feel soggy.
When you pull your old one out make sure you don't lose the pin that slides into the back of the modulator.
Old Oct 28, 2023 | 10:43 AM
fordforlife62
8th Gear
Early shifts
Thanks for the info. Should have it next week. See what happens. Thanks
fordforlife62
Oct 27, 2023 07:43 PM
jakeharp
Mar 3, 2017 07:03 PM
jakeharp
Feb 27, 2017 06:39 PM
89GTAWS6
Aug 13, 2013 06:45 PM
Muddy701
Apr 30, 2013 05:07 PM
