Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Carburetor question.
Old Oct 27, 2023 | 06:42 AM
pfogle's Avatar
pfogle
I know this has been answered a million times, but my old governed carb is leaking and I'm not sure it's fixable without excessive expense. Can I replace it with a standard vacuum secondary 600cfm unit? It's in a 1975 F600, on a 361 with a 4bbl.
Old Oct 27, 2023 | 01:22 PM
LeadWorker's Avatar
LeadWorker
2nd Gear
Talking
Yes. You just have to plug (I remove the vacuum control lines at their source to clean it up.) and then drive it like a human being with intelligence and not just keep it floored.
Old Oct 27, 2023 | 07:21 PM
85e150's Avatar
85e150
As to your old carb--have you been through it with a proper rebuild kit, all new gaskets, etc?
This is a different carb, but discusses a fix for a warped power valve cover for example:
https://www.ford-trucks.com/forums/1...l#post21013050
Old Oct 27, 2023 | 09:19 PM
garygnu's Avatar
garygnu
if you disable and plug the governor any holley vacuum secondary 600 carb should work
Old Oct 28, 2023 | 06:51 AM
pfogle's Avatar
pfogle
I'm going you drop it off to a local parts store that does a lot of rebuilds on these. I'm considering swapping to efi with a Holley sniper, or running an msd box to keep the governor. The killer is I drove this thing home a year ago.
pigpen60
May 2, 2016 07:17 PM
r_reed
15
Sep 5, 2011 08:16 AM
strider9
Dec 12, 2005 06:15 PM
jimbo81587
Jan 28, 2004 03:48 PM
