AOD no upshift
Recently, I’ve swapped in a used AOD from a 89’ Town car into my 86’ F150. Had the driveshaft shortened(tail shaft on the Lincoln trans was a bit longer), then encountered a line leak that resulted in a loss of pressure, so I replaced the lines, and topped her off with fluid. First test drive and I realized that it wouldn’t shift out of first. Tv cable seems to be fine.Any ideas as to anything else I might have overlooked? Thanks.
https://www.google.com/search?q=how+...client=gws-wiz
