Stick brake pedal
Old Oct 21, 2023 | 11:11 AM
gabriell12123's Avatar
gabriell12123
Stick brake pedal
Okay so I’m having a issue with my brakes, (project truck that was sitting for a few years) with motor off the brakes feel good and work fine, with the motor running sitting still the brakes feel good and seem to work fine, however if you drive down the road and hit the brake pedal you have to pick the pedal up each time, when sitting still the pedal brings itself back up. Couple of things you should know, I swapped the cab on this truck and I converted it to manual at the same time. The pedal assembly is correct for the truck and I did on the bearings and shims on it and it’s greased up, if I take the brake pedal off the brake booster arm there’s no binding at all, it’s got a good smooth swing all the way up and all the way down I’m trying to put this thing on the road and need the brakes fixed
kylant
Jun 6, 2022 09:09 AM
grafhky52
6.7L Power Stroke Diesel
17
May 28, 2012 08:12 PM
harleymsn
Jul 15, 2010 10:20 PM
carcrafter22
Jul 9, 2008 05:01 PM
