ok and P1119 is an issue with your manifold air temp sensor.
P0340 is an issue with your CPS or CPS wiring.
P0470 is an exhaust backpressure issue.
P1210 is a stuck IPS or IPR pigtail wiring issue.
P1139 is water in fuel bowl.
I suggest you check your wiring to each as far as you can in to the harness because due to the age we keep seeing wiring issues.
__________________ Jody & Diane Tipton- DP-Tuner® FTE Legacy Sponsors since 2006 Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost, Get Tuned!828-221-0076 ext. 802 Become our Facebook Fan
sorry if this is stupid but why is there no wait to start I have power running to the pcm and the pcm is good all the fuses are good the diode is good and relays but still not wait to start
