Help Identifying Hose
Old Oct 19, 2023 | 02:35 PM
Handsome Bob's Avatar
Handsome Bob
Hey guys, I need help identifying this hose. Its on the rear passenger side of my 03 4X4. Its leaking and it smells like coolant but I wanted to make sure. Also how difficult is it to replace? Thanks!!!
Old Oct 19, 2023 | 03:38 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Related to rear HVAC.
The Excursion has two heater cores, fed by two coolant circuits.
Old Oct 19, 2023 | 04:05 PM
Handsome Bob
Its right next to my fold down steps. I was thinking it might be hydraulic fluid? Its really thin but has a slight oil texture.....
Old Oct 19, 2023 | 04:44 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
HVAC = Heater, ventilation, and Air Conditioning.
So in addition to having a heater in the rear, you also have a rear air conditioner, and as such, the "slight oil texture" of the "hydraulic fluid" you are reporting sounds like refrigerant oil.
The lines are aluminum, fragile, and can develop leaks. If the lines were disturbed in the process of adding motorized running boards, the probability of the disturbed lines developing a leak is higher.
To find any leak in any closed system, TRACER DYE that is compatible with the fluid being tested is the quickest and most accurate way to locate and pinpoint the leak(s).
Members of FTE with Excursions have contributed a lot of information on rear HVAC line leakage.
Here are just a couple of threads, but there are hundreds of other posts in other threads that may even be better, that are only a search away.
Rear AC Lines FTE
Repair Rear AC Lines with Pictures FTE
Old Oct 19, 2023 | 05:19 PM
Handsome Bob
Rear AC Lines FTE
Very much appreciated!!!!
ZekeD
Nov 3, 2022 01:14 AM
Vlad91
May 5, 2022 04:14 PM
redrock5.9
Feb 23, 2022 06:17 PM
pnw_living503
Jul 19, 2021 05:14 AM
Bohen
6.7L Power Stroke Diesel
May 3, 2020 05:13 PM
