2004 Transmission Overheating
Old Oct 22, 2023 | 10:19 AM
redfishtd's Avatar
redfishtd
I would not go against this engineers facts . I am an old guy so we used the 200f as a trouble point at the trans cooler in front of the radiator. I was climbing a mountain with a heavy load and blew a lot of the hot trans fluid out before it reached the top . So I pulled over and let it cool for a couple of hours . No store up there for more fluid .
I believe in the extra cooler and the tow package plus reducing speed helps a lot .
My vehicle made it thru without noticeable damage . I have an aftermarket pan on this one so I can easily change fluid 4-5 quarts at a time over several weeks until 20 quarts or so is flushed , this may not be the best way but it's my way .
The aftermarket pan reduces the mess of dropping a pan . Not a fan of adding a drain to factory pan but it can be done depending on your skills . I would weld one if i did it , it's like the oil change, it depends on how hard its been pushed . Changing is a prevention not a cure .
Cardboard sheets underneath will help mitigate the fluid mess , I just helped my friend change his dually ram with 9 quarts in pan , he could only suck 4 quarts out thru dipstick so it made a mess . Many rolls of paper towels barely cleaned it . We had to put him in the shower and dawn out the garage. Fluid was very brown and had 130k on it with heavy towing . His other truck trans went bad at 30k and looked like it got water in it 4 grand later for a rebuild . So he was very nervous about this work truck .
wallz
May 17, 2023 04:38 PM
fletchyjack
2009 - 2014 F150
Jun 25, 2022 08:04 PM
Burrr
2004 - 2008 F150
Mar 20, 2017 05:18 AM
Soccerpj
1978 - 1996 Big Bronco
Jan 22, 2015 10:45 AM
hreyesg
May 7, 2013 07:49 PM
