1978 - 1996 Big Bronco
Radiator burst through plastic
Old Jan 22, 2015 | 06:10 AM
Soccerpj's Avatar
Soccerpj
I changed my transmission fluid took it for a drive a noticed it was reving up a little high. 3000 RPMs and I was only going 25. Before the fluid change I didn't have this problem. So I brought it home to check the fluid level again as I was checking antifreeze shot out through the plastic leaving a 6 inch size crack next to the lower transmission line. I did buy a new radiator, cap and thermostat but I'm a little reluctant to drive it again without knowing any idea of what caused any of this.
Old Jan 22, 2015 | 10:45 AM
Kemicalburns's Avatar
Kemicalburns
did you install the Tstat correctly? if its backwards that could be your issue causing to much pressure
TheKid1
6.7L Power Stroke Diesel
Sep 18, 2011 03:37 PM
A star
Aerostar
Jan 15, 2007 07:17 AM
Nathane
May 14, 2006 03:29 PM
GeneStoner
Mar 7, 2003 06:10 PM
