2020+ Explorer Discuss the rear-wheel-drive 2020+ Explorer
2020 Ford Explorer
Old Oct 16, 2023 | 11:28 PM
dyer11's Avatar
dyer11
3rd Gear
2020 Ford Explorer
On my 2020 Explorer they recently added a new component to where the E-brake is engaged once it's switched to park..Now a couple months later my shock is leaking fluid and is bad. I believe this is from the brake being engaged and the shocks being compressed. Anyone else have this issue?.
Old Oct 17, 2023 | 03:33 PM
AACoPD05's Avatar
AACoPD05
Seems odd. The e-brake "update" was a patch job to keep the vehicle from rolling away due to the recall that dealers can't seem to fix yet because of a tool back order issue. I can't see how the two correlate though.
Old Oct 17, 2023 | 08:37 PM
dyer11's Avatar
dyer11
3rd Gear
When you put it in park it squats the back end of the vehicle down probably a good 1" or 2 and stays that way until you put it into drive and release the E-brake. So to me that's a lot of pressure on the shocks for an extended time. I'm thinking that's why the seal on the shock blew out. . Thanks for the feed back.
Old Oct 18, 2023 | 02:27 PM
AACoPD05's Avatar
AACoPD05
Gotcha, I'll have to see if mine does that next time, but I use my e-brake because I park on a slight decline. If it is related then I feel like Ford should replace it since it was their "fix" in the first place.
Old Oct 19, 2023 | 01:39 AM
dyer11's Avatar
dyer11
3rd Gear
They should,.it only has 38,000 miles on it.
Old Oct 24, 2023 | 06:30 AM
AACoPD05's Avatar
AACoPD05
No noticeable squat when I put the e brake on, mine does not do it automatically though. I back into my driveway, foot on brake, put it in park, turn on e brake then foot off the brake. Doesn't squat at all, I'm also on a slight decline whereas the front it lower than the rear.
00Explorer00
17
Jul 22, 2013 12:42 AM
YoGeorge
Sep 6, 2009 01:58 PM
micgang
May 4, 2004 10:00 AM
ronniev
Mar 4, 2001 09:49 PM
