Stuck in Regen?
Old Oct 16, 2023 | 08:01 PM
TrikeDawg's Avatar
TrikeDawg
Stuck in Regen?
My 2022 F-350 wit the 6.7 seems to be stuck in regen all of the time while towing a 12,000 toy hauler. The particulate filter always stays at 0% while towing on a recent 400 mile trip. I filled my DEF tank up full to the top and after driving 20 miles, the gauge says my range is 1,600 miles which makes me think something is wrong.
Any ideal what the problem may be?
Old Oct 16, 2023 | 08:36 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
My 2022 F-350 wit the 6.7 seems to be stuck in regen all of the time while towing a 12,000 toy hauler. The particulate filter always stays at 0% while towing on a recent 400 mile trip. I filled my DPF tank up full to the top and after driving 20 miles, the gauge says my range is 1,600 miles which makes me think something is wrong.
Well, you do not have a DPF tank.
You should have a DEF tank.
And, DEF has ZERO to do with the DPF or regenerations, they are two separate systems.
And, your truck will be performing "passive" regeneration while towing, as the exhaust temps generated while towing are usually high enough to accomplish the DPF soot burn off without any active regeneration.
So, I would not worry about what you are seeing.
Old Oct 16, 2023 | 08:37 PM
4wd6.7L's Avatar
4wd6.7L
Isn't that normal when towing, passive regen? Since DEF use increases with fuel use it also makes sense that towing would use more of both.
Old Oct 17, 2023 | 05:02 AM
HeavyAssault's Avatar
HeavyAssault
Passive regens are usually happening with EGTs over 650*F+, I'd suspect any towing of a 12k trailer is going to fit that bill day-in, day-out. My Insight CTS3 shows the info I need.
Old Oct 17, 2023 | 05:26 AM
senix's Avatar
senix
The passive regen happens when you get the EGT temps up there.
Simply....non towing equals lower temps allowing the soot to build causing an active regen. This means the soot level increases.
This also means very little DEF is used.
When towing or heavy hauling then the temps increase and the complete opposite occurs.
So in short as said above, drive on.
Old Oct 17, 2023 | 05:45 AM
harmanrk's Avatar
harmanrk
For what it's worth, when driving unloaded I average about 1000 MPG on the DEF. so 7.5 gallon tank I am filling about every 7000 miles, or I was when I was going on distance. These days when the gauge show 1/3 of a tank I add 2.5 gallons to bring it up to 2/3. I never fill it to full anymore. I don't drive the truck a lot in the winter and had constant concerns about a frozen and busted tank one winter so I leave room for expansion now.
Old Oct 17, 2023 | 09:07 AM
Strider250's Avatar
Strider250
On my recent 3000 mile trip with a 7K TT the DPF was at 0 most of the trip. My def consumption went from 758 mpg unladen to 438 mpg towing.
Old Oct 17, 2023 | 10:17 AM
redford's Avatar
redford
FTE Leadership Emeritus
Everything is normal. Relax and enjoy the open road.
Old Oct 17, 2023 | 12:56 PM
Flatland1's Avatar
Flatland1
So is that exhaust filter percentage a forscan thing? My 2022 F 250 doesn't have that screen.
Old Oct 17, 2023 | 01:13 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by Flatland1
So is that exhaust filter percentage a for scan thing? My 2022 F 250 doesn't have that screen.
The exhaust filter percentage full screen is for diesel trucks. If your truck isn't a diesel you won't have that screen.
Old Oct 17, 2023 | 02:09 PM
Flatland1's Avatar
Flatland1
Don't want to come off as a smart ***, but I've been pumping diesel in it since December of 2021, so I guess it is a 6.7 PowerStroke.......
I have went to my truck twice today to see if I could find that screen..........I can not.
Any hints as to where it might be? I think it would be nice to have.
Old Oct 17, 2023 | 02:50 PM
cmk1's Avatar
cmk1
Turned on via forscan or have your dealer turn it on.
Old Oct 17, 2023 | 03:11 PM
senix's Avatar
senix
for 2021 and up the dealer cant enable the DPF soot screen.
Forscan can.
Old Oct 17, 2023 | 03:14 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Part of the new dash screen on 23's.
Old Oct 17, 2023 | 03:47 PM
Strider250's Avatar
Strider250
For my 2023 it can be found on the measurements screen, which may not be defaulted from the factory. When on the measurements screen press OK on the steering wheel to scroll through the 3 measurement screens, The DPF and DEF are on the third one. To get to it select "Menu", then "Select Screens" and select the measurements screen. You may need to deselect one of the other screens as the number that can be scrolled is limited. I am not sure if your model year is similar.
Bruce M.
All Things Towing
121
May 14, 2024 11:24 AM
cat-alac
Dec 21, 2021 08:25 PM
Squirrel13
Jun 4, 2021 06:49 AM
82_F100_300Six
Jul 22, 2019 10:42 AM
Rick Cargo
6.4L Power Stroke Diesel
18
Nov 18, 2011 08:45 PM
