96 Ex AWD Question
Old Nov 21, 2003 | 01:20 PM
Tourist's Avatar
Tourist
96 Ex AWD Question
This is the first AWD I have ever owned. When making sharp turns do you get that binding noise as you do with regular 4WD when they are engaged?
Old Nov 21, 2003 | 01:24 PM
emtabmm's Avatar
emtabmm
Yes, especially if there is any loose gravel on ground...
The system works by measuring wheel speed at each frt wheel and 1 sensor on rear diff., tight turns the outside wheel turns much faster than inside and activates system.....
Old Nov 21, 2003 | 01:27 PM
Tourist's Avatar
Tourist
Thanks! I thought that may be the case but I was not sure.
Old Nov 22, 2003 | 11:50 AM
c96drumm's Avatar
c96drumm
I believe my 96 AWD just drives the front wheels through an open differential which is in turn driven by a viscous clutch in the transfer case.
Old Nov 22, 2003 | 03:54 PM
ford_tr_man's Avatar
ford_tr_man
no there's NO grinding/binding on sharp turn's!!!!!
Old Nov 22, 2003 | 04:39 PM
c96drumm's Avatar
c96drumm
Me, neither.
Old Nov 22, 2003 | 09:33 PM
Tourist's Avatar
Tourist
So which is it? I am talking about very slow tight turns?
Old Nov 22, 2003 | 10:06 PM
c96drumm's Avatar
c96drumm
Do you have the standard size tires on there? Otherwise, could be a CV joint or the differential. I think CV joints usually make a clicking noise when they're failing, but might be something to look at. Also, I saw another thread you might want to look at:
https://www.ford-trucks.com/forums/s...hreadid=158436
Old Nov 23, 2003 | 08:19 AM
drcoffee's Avatar
drcoffee
Yea, I have a slight moaning sound which I believe is typical in a tight, slow turn. It sounds like it may be coming thru the transfer case and not the wheels.
Old Nov 23, 2003 | 08:20 PM
sllt96xlt's Avatar
sllt96xlt
yea there should definately be no grinding sounds.
Old Nov 23, 2003 | 09:16 PM
Tourist's Avatar
Tourist
There is no grinding sound. There is just a binding noise like with a normal 4wd.
