Sponsored by: Real Truck
Flywheel problems
Old Oct 13, 2023 | 09:19 PM
2008lariatf250's Avatar
2008lariatf250
4th Gear
Flywheel problems
So i have a 2008 F-250 with the 5.4 triton, the transmission has just over 236,000 but the motor has been replaced and has around 40,000 on it, a couple months ago i had this knocking noise that would come and go whenever my truck would start after sitting overnight and then it finally let go on me. After 4 weeks i put a new flywheel in myself with all the torque specs being right on the money, well last night it happened again but didn’t have any noises until it let go im just curious does anyone have this same issue and what is the reason that this could’ve happened twice now?
Does my truck need a gear reduction i have 37x13.50R18 and if so what is a good gear ratio to go to for better mpg, and less strain on the drivetrain?
Old Oct 13, 2023 | 11:54 PM
reptar0077's Avatar
reptar0077
That was sorta hard to understand.
So its a knocking sounds only when starting it up & turning the flywheel with the starter motor?
Or its a sound when its running in idle while its warming up?
Old Oct 14, 2023 | 03:11 PM
2008lariatf250
4th Gear
Both of these it would knock really hard when starting then only knock slowly at idk when warming up
qman
Jun 3, 2015 04:21 PM
5150 fear
13
Jun 10, 2014 10:21 PM
1982fordf100
Jun 17, 2006 02:02 PM
Dustin_86
May 15, 2004 11:08 PM
Varnish
Apr 27, 2002 01:31 PM
