problem bleeding my clutch
Old Nov 21, 2003 | 12:07 PM
Fat_Gozar's Avatar
Fat_Gozar
Angry problem bleeding my clutch
Hello, I have a 94 f-150 2wheel drive 4.9L with the mazda trans. I went through the process of replacing the clutch and slave. All went well untill I tried to bleed the new slave. I opened the bleed screw and waited until the fluid ran without air. closed the screw and pumped the pedal 50 times as told in the manual. The pedal didn't feel right so I though there still was air in the system so I open the bleed screw again and some fluid came out and stoped. Now I can't get ANY fluid flow through the slave. All connections are good and every thing seems to be right except gravity! Any help would be greatly appreciated
Old Nov 22, 2003 | 10:59 PM
stevieray's Avatar
stevieray
You may have a blockage in the bleeder valve. Have you had someone depress the clutch while you bleed the clutch?
Old Nov 23, 2003 | 06:37 PM
steve83's Avatar
steve83
The master cylinder is airtight - you have to remove the cap so fluid can drain down. Be SURE to remove the rubber diaphragm BEFORE adding fluid!
Old Sep 28, 2024 | 12:38 PM
Max Capacity's Avatar
Max Capacity
Found this thread, thought this might help,
Kevinred
Aerostar
Dec 7, 2008 03:50 PM
specialist484
Jul 4, 2007 10:58 PM
Charger73400
1983 - 2012 Ranger & B-Series
Dec 4, 2005 11:53 PM
stevehir
Aug 16, 2002 06:20 PM
boris
Aug 4, 2002 09:23 PM
