Bleed Hydraulic Clutch
Old Nov 15, 2000 | 11:33 AM
stevehir's Avatar
stevehir
Help... Have 1983 Ranger 2WD 6cyl 2.8. Replaced Master Cyl. & Slave Cyl. Filled with Fluid and can't get the thing to bleed. Is there a special procedure to Bleed the clutch. I have pumped the Master, but it seems to introduce air into the line. I can Bleed brake lines like a champ but this Clutch line is something I haven't done before........Everything except the line between is brand new...Please Help
Steve
Old Nov 15, 2000 | 06:07 PM
jeepls's Avatar
jeepls
Here's something I've done on an F150 and a jeep wrangler. I would just crack the bleeder open and let the fluid run out for awhile keeping the reservoir full. Might have to do it a few times. I know that pumping the pedal does make more air in the system. If you have a helper, just have them press the pedal down once but don't pump it. Then open the bleeder. But the first method always worked for me.
Old Nov 15, 2000 | 11:10 PM
PAUL_2's Avatar
PAUL_2
Leave the cap off the Clutch master cyl when you open the bleed screw & it should bleed just by gravity . Keep an eye on the fluid level . Leaving the cap on prevents outside air pressure from letting the fluid drain .
Old Nov 16, 2000 | 03:20 PM
stevehir's Avatar
stevehir
seems to just pour straight through still leaving air in the line....should I try closing it alittle and constricting the flow or just keep letting it drain until it fills. all is, is a small hole beneath the allen bleeder screw. Loosen the screw and it comes out the small hole
Old Jul 31, 2002 | 03:05 PM
brokebronco's Avatar
brokebronco
Old Aug 16, 2002 | 06:20 PM
RM_HM's Avatar
RM_HM
The clutch on my 2000 ranger 3.0L 15,000 miles gained about 2 in of free play. So I decided to bleed it. I got many bubbles and about a 1/2 teaspoon of a white grease like substance out of the system. My clutch is now acting more like it used to.
Anyone seen anything like this?
rangerford
1983 - 2012 Ranger & B-Series
83
May 22, 2024 08:48 PM
hotrod91174
Nov 16, 2020 09:31 AM
beersy50
Dec 6, 2015 12:41 PM
srumble
Nov 17, 2007 06:36 PM
sparkemon
Jan 27, 2006 09:50 AM
