We have seen a ton of cool upgrades and changes to the T4 world in the last year or two. A lot of you have spent your hard earned money on going to a 363 or smaller exhaust housings, and just experimenting and reporting the results. Some have tried the turbonator which seems to have amazing results but some hardships to get to those results.
I keep an eye on the 7.3 Facebook groups too and someone posted this. I don’t think it would work as good as a turbonator which has more benefits once the kinks are worked out but what are your thoughts on this? May be a happy medium, less moving parts, help spool up a little.
Would have to cut out the twin scroll of the T4 flange on the motor. It may not flow quite enough from both banks of the engine unless the up-pipes were redesigned. Just brainstorming, I have often wondered how well those work.
I gather the basic idea is you can use a bigger turbo with this thing. Helps bridge the big/small turbo gap. It restricts volume of airflow down low so the speed of the air that passes is faster. This increases turbine speed at low boost levels so the big turbo comes on sooner down low. Then when it opens up (controlled how I dunno) you get full boost from the big turbo.
Or are we even talking about the same thing? What I'm talking about the the type of exhaust housing that has the moving vanes in them that change the angle of attack in relation to the position of the exhaust turbine wheel.
For the 7.3 with a VGT (DPS Turbonator) yes its needed.
Well, OK. Without studying up on their engineering strategy I'll just accept this answer for that particular application. It's just the first time that I've ever heard of a diesel engine with no throttle plate requiring a blow off valve.
The way the actuator controls the vanes causes the turbo to surge under certain situations requiring a BOV.
That seems like a backwards way of doing things. The way my TDIs are tuned is the vanes default to wide open and a vacuum controlled actuator pulls them closed. When the PCM sees enough boost, it releases the vacuum to the canister and the vanes open up. At idle, the vanes are fully closed and when checking on things with the Vag-Com it will actually show a few millibars above atmosphere at idle. No blow off valve in this design or in any other diesel from them that I am aware of.
