Insulation Pad Behind Cab
Old Oct 8, 2023 | 05:13 PM
aklim's Avatar
aklim
2017 F250. IDK what it is called but there is are 2 insulation pads behind the cab on the exterior. The left seems to be fine. The right seems to be rattling when I am over 40 mph. Questions:
1. What exactly is this pad for?
2. Can it be removed totally?
3. Can it be glued down without covering a vent or hurting something?
Reason I ask is that I have seen it on other trucks and it looks like it is not covering a vent. I need to know because there is a cap on the bed so it isn't the easiest to get to. TIA
Old Oct 8, 2023 | 05:28 PM
4wd6.7L's Avatar
4wd6.7L
This might answer some of your questions. https://www.ford-trucks.com/forums/1...b-and-box.html
Old Oct 8, 2023 | 05:32 PM
aklim's Avatar
aklim
It did. Now to find some kid with smaller hands to either get to it and glue it back without taking the box off. Thanks. If anyone has an idea that doesn't involve removing the cap and the bed, it would be better.
Old Oct 9, 2023 | 09:10 AM
HRTKD's Avatar
HRTKD
I wonder if the edges should be sealed, like with sound insulating panels on the inside. When I put sound insulation panels on my side-by-side, I taped every edge.
Old Oct 9, 2023 | 10:38 AM
aklim's Avatar
aklim
Obviously not that well sealed. It's going to be a tricky thing to do with the bed on and a cap on the bed.
Old Oct 9, 2023 | 01:12 PM
acdii's Avatar
acdii
Use two sticks. One to lift and hold the pad, the other to apply glue. Maybe look to see if they are easier to get to from underneath.
Old Oct 9, 2023 | 01:20 PM
aklim's Avatar
aklim
Good idea. Thanks
MarkG.
Oct 26, 2012 03:07 PM
chris-in-LA
Apr 21, 2011 08:59 PM
jake00
Jun 11, 2007 07:49 AM
Bouts21
31
May 26, 2007 11:19 PM
nlancasters
Jan 27, 2007 11:04 AM
