Sponsored by: Real Truck
Shaking and pulsing when braking
Old Oct 7, 2023 | 09:55 PM
raider5152's Avatar
raider5152
1st Gear
I have a 05 f350 single rear wheel with the 6.0. Shakes bad and brake pedal pulsates as soon as I touch the brake pedal at any speed with any amount of pressure on the pedal. All new pads and rotors even exchanged them thinking I had a bad batch. Any info would be appreciated
Old Oct 8, 2023 | 06:57 AM
hodge5's Avatar
hodge5
Have you checked your front unit bearings, tie rod ends, track bar? Usually, shaking and pulsing comes from warped rotors, but if you've replaced them twice with no change, then I would look at worn front end components next.
Old Oct 8, 2023 | 08:25 AM
bajaphile's Avatar
bajaphile
Was it happening prior to your brake job? How long was it like this for? Did it happen gradually or suddenly? What size/type of tires?
Old Oct 8, 2023 | 09:30 AM
speakerfritz's Avatar
speakerfritz
My vote is water in the brake fluid. Completely drain at all corners…vacuume it all out, refill, bleed air.
Old Oct 9, 2023 | 06:07 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Agree with all of the above, check all front suspension components for wear/play, replace anything that's bad, make sure you tightened everything down and that your slide pins on the calipers are moving freely, bleed the brakes pretty good, then install the wheels and take it for a drive. Something in there should take care of the issue. If not then it's the tires, but if it wasn't doing this before your brake job then chances are you got something installed wrong.
Make sure you removed the old 'shims' for the ends of the pads and replaced with new ones, and that you used a high-quality synthetic brake grease too.
Old Oct 9, 2023 | 07:05 AM
irydasteelhorse's Avatar
irydasteelhorse
pop the fuse for your ABS and take it for a drive. mine was similar, and its an easy thing to try to narrow it down.
gsxr1300
6.7L Power Stroke Diesel
21
Jun 22, 2019 06:00 PM
Redfridge
Oct 26, 2013 04:27 PM
umtigers
Oct 11, 2005 05:01 AM
MontanaFord
Aug 12, 2004 10:02 PM
