Electrical problems?
Old Oct 7, 2023 | 01:27 PM
DavidDookie's Avatar
DavidDookie
1st Gear
Hi everyone, my 87 f150 2wd granny 4 speed won't start. The previous owner had a button wired to the solenoid to start it but whenever you push it the solenoid will click and then the battery just shuts off. The engine also shut off while driving and I was able to coast into the driveway and it's sat there ever since. What do yall think, thanks in advance
ps. I took the starter and battery to O Reily's and there good
Old Oct 7, 2023 | 02:36 PM
88n94's Avatar
88n94
I know you had the battery out when you took it to O Reilys, But i would take the battery cables off the battery posts again and make sure the inside the cables where they hook onto the battery posts and also clean the outsides of the battery posts and then make sure they tighten up properly. Also clean the other side of the battery cable that hooks onto the negative battery post. Make sure the connection on the fender mounted solenoid where the other end of the positive battery cable meets all the other wires is clean and tight That should solve your loss of all battery power problem..
Old Oct 7, 2023 | 02:57 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by DavidDookie
The previous owner had a button wired to the solenoid to start it ….. What do yall think…
The ignition actuator broke or possibly the switch was on its way out so they rigged it to start instead of actually fixing the problem.
Nswenn
17
Jun 23, 2022 04:39 PM
Jonesy0027
Feb 17, 2020 06:12 PM
74scamp
Jan 4, 2010 09:50 PM
ford150driver
Jul 8, 2004 12:21 AM
TexasF1
May 14, 2003 07:37 PM
