Hey CC77 You are the Bomb Dude!
I have a 97 Explorer Eddie Bauer.First 1 headlight went out,so I replaced the bulb.nothing.But my hi beams worked.Then soon after the other headlight went dead and my brakelights were gone.Your description of the problem and how to fix it was Right on!Just wish I found your post before I spent 2 days on this problem and have half of truck torn apart.Let me know when you get your website together.
You are a Lifesaver!
Thanks
vortechx
CC77 hasn't been on here since 2004, so I doubt he will read this, but glad you fixed your vehicle.
I had the same headlight issue on a 95 explorer eddie bauer... No driver side low beam.. good bulb.. good fuse.. etc. After pulling out the LOM it does have an obvious loose pin, the solder apears cracked all the way around the connection where it goes through the board on the back side.. I am going to have a friend who works on circuit boards solder the pin back in this week and will update on my results.
That seems to have been the problem. Had the pin soldered back in yesterday and headlights are working great! Thanks to all who contributed to this thread!
