Bluetop porting option
Old Oct 4, 2023 | 06:53 PM
Anonymous12's Avatar
Anonymous12
https://bluetopsteeringgears-com.3dcartstores.com/2757-80-97-Ford-F-series-Trucks-Broncos-Rangers_p_24.html
I was looking at this trying to see what it would cost to get one, would the porting be for the PS pump, or is that something different?
Old Oct 4, 2023 | 07:26 PM
dustyroad's Avatar
dustyroad
What is Porting?
The porting option is used if you have or are planning on adding a hydraulic ram assist system on your vehicle. It is an added on aftermarket option and does not come standard with your vehicle. This is mostly used if you have a lift kit and run oversized tires. If you are doing a factory steering gearbox swap you would not need this option.
*Hydroboost brake systems have nothing to do with porting. The gearbox comes standard with pressure and return ports for normal operation.
https://bluetopsteeringgears-com.3dc...FAQ_ep_43.html
I am very happy with my bluetop , I do not have it ported. I don't have a hydroboost.
Old Oct 4, 2023 | 07:29 PM
JJF20's Avatar
JJF20
I believe what you’re looking at is porting for hydro assist…
Google ‘hydro / hydraulic steer assist’. mostly used off road, helps for turning big tires at slow speeds.
cfpinz
6.7L Power Stroke Diesel
36
Nov 5, 2025 01:22 PM
Jacksonb15
Nov 7, 2020 01:07 PM
Opossum
Jun 26, 2010 12:41 PM
blkbeast
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 18, 2008 05:43 PM
