2000 v10 which ATF
Old Oct 7, 2023 | 10:15 AM
kevin.ford-trucks's Avatar
kevin.ford-trucks
I've been using Mark's procedure every 30 to 40K. Maybe 50 or 60K is adequate? 5K of that is towing
Old Oct 7, 2023 | 11:18 AM
Ted722's Avatar
Ted722
Well, I guess I'll be the crash test dummy!
Wanted to baseline my '03 V10 4R100. First, just to do it as I picked up the truck early last year and didn't see any service history on the transmission. Second, noticed a hard shift every once in a while into reverse or a shudder-hard shift every once in a while into 4th.
Let my local trusted shop know (known the owner 20+ years), he checked the fluid (and although it looked good) , recommended going across the street and have it flushed, no filter change. Had Jiffy Lube flush with Pennzoil High Mileage ATF. They charged for 17 quarts @ $7 a quart. Labor $89. $215 total.
Truck has 100K miles on it and the last 500 miles since the flush has shifted smoother across the board and the reverse / 4th gear issues noted above are gone.
I'll keep you posted if I run into any issues.
Old Oct 7, 2023 | 03:46 PM
kevin.ford-trucks
You got an 03 with 100k! Let me know if you tire of that old style My 00 exc has 258k and the v10 drinks about 1Q of oil per 1500 miles. The big decision is do I keep pouring $ into it including new engine at some point, body work, or do I ? Nothing much compares.
Old Oct 7, 2023 | 03:54 PM
kevin.ford-trucks
I wonder what a "flush" really means. Having done Mark Ks procedure and the one he linked above for the newer transmission those seem like "flushes". At least in that all the old is pushed out by the new.
kevin.ford-trucks
Oct 10, 2023 09:49 AM
sgc2c
Apr 24, 2021 04:23 PM
alabbasi
Nov 1, 2016 10:28 AM
Gary E K
Modular V10 (6.8l)
21
Apr 1, 2004 09:05 PM
MX429
Dec 31, 2003 04:44 PM
