Clunk sound When I stop/start - Ford Truck Enthusiasts Forums
Old 06-22-2003, 09:09 AM
t4kne
t4kne is offline
t4kne is starting off with a positive reputation.
I'm driving a 93 F150 XL. Every time I come to a stop I hear a clunk that sounds like it's coming from the front end. The same is true when I start moving again. It does not sound/feel like the drive shaft. It's just a single clunk/thunk sound and that's it. I can't see anything wrong anywhere. Sound familiar to anyone? A Ford thing? Thanks for your input.
Old 06-22-2003, 12:38 PM
flyboy2610's Avatar
flyboy2610
flyboy2610 is online now
flyboy2610 is gaining momentum as a positive member of FTE.
You may have a broken or loose motor mount.
Old 06-22-2003, 04:01 PM
longview1's Avatar
longview1
longview1 is offline
longview1 is gaining momentum as a positive member of FTE.
Yeah man,
I notice the same sort of thing in my 78 150. When i come to a stop on the brakes i hear/feel a clunk, not always, but often enuogh to chap my a$$. I havent found the cause yet, u-joints, balljoints, driveshaft all good/tight. Motor mounts are all good as well....I think. I will go check that actually.
G'luck to the both of us.
Old 06-24-2003, 12:41 PM
1BadF-350
1BadF-350 is offline
1BadF-350 is starting off with a positive reputation.
Had the same problem. Turns out it was loose u-bolts, the axle was knocking around on the spring perches.
Old 06-24-2003, 01:10 PM
t4kne
t4kne is offline
U-bolts on the rear axle? Never gave that a thought because this sound I'm talking about seems to be from the front. I'll check anyway. It could be that the sound is transfered through the frame I suppose. I was under there yesterday doing rear brake lines and didn't see anything. I'll double check. Thanks.
Old 06-24-2003, 07:31 PM
1BadF-350
You might feel it in your seat and assume it's up front.
Old 06-24-2003, 08:50 PM
t4kne
t4kne is offline
I checked the u-bolts when I got home today, they seemed tight. I couldn't move them and they lo0oked as thought they had not moved (rust in tact). I layed under there for a while just looking around. I don't see anything. Checked the motor mounts. they look ok.
Old 06-24-2003, 09:40 PM
vman
vman is offline
vman is starting off with a positive reputation.
I replaced everything on the front of my 93. I still had a clunk starting and stopping and sometimes turning. Turned out to be the axle pivot bushing was shot, but was really hard to tell.
Old 06-29-2003, 08:17 AM
13hondacr250's Avatar
13hondacr250
13hondacr250 is offline
13hondacr250 is starting off with a positive reputation.
95 F-150, same friggin problem. I can feel it on the floor boards. Last october I replaced EVERYTHING under the front end, bushings to diff seals to u-joints to bearings. And it still clunks. Unlike Longview1 it does chap my a$$! My truck makes more noises than a haunted house in october.
Thanks
Tyler
95 F-150 302 5 speed
94 F-250 PSD 5 speed
Old 06-29-2003, 01:53 PM
RRMike's Avatar
RRMike
RRMike is offline
RRMike is starting off with a positive reputation.
Grease the slip joint on the rear driveline. I hear this will cause a clunk. It binds up when it gets dry.
Old 06-29-2003, 05:42 PM
13hondacr250
At this point I'll grease the brakes it the clunking stops. Thanks
Tyler
95 F-150 302
94 F-250 PSD
Old 06-29-2003, 11:28 PM
plumbkrazy
plumbkrazy is offline
plumbkrazy is starting off with a positive reputation.
hi , i had the same noise it was the radious arm bushing.
after market kit is better than the oem.
its a crappy job to do but it worked . clunk is gone.
Old 06-30-2003, 08:34 AM
fomoco's Avatar
fomoco
fomoco is offline
fomoco is starting off with a positive reputation.
I too have experienced that @%% chappin sensation..
The transmission mount was broken...right where the rubber insert binds the upper and lower part of the mount.
It was impossible to see... but I put a floor jack on the rear of the trany and very gently raised it from the rear... sure enough broken mount.
Old 07-02-2003, 08:05 PM
Nickiboy
Nickiboy is offline
Nickiboy is starting off with a positive reputation.
If you have leaf springs up front and haven't checked the bushings as yet Im willing to bet its where ya troubles lay........If your bushings are worn then the springs lift and drop on take off and stop causing that clunking sound.
Old 07-02-2003, 10:02 PM
t4kne
t4kne is offline
No leaf springs, it's coil springs, Dana 44 IFS front end. Thanks everyone for the suggestions. Still no luck. Had the front end aligned yesterday. They couldn't find anything either. The clunk lives on.
Quick Reply: Clunk sound When I stop/start
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
