5th wheel/gooseneck prep package
Old Oct 2, 2023 | 07:57 PM
NGH's Avatar
NGH
So I have always done B&W goose neck after market. If you do the 5th wheel/gooseneck prep package what all do I have to get aftermarket?
Old Oct 2, 2023 | 08:01 PM
Kameron Rice's Avatar
Kameron Rice
$250 gooseball. Stick it in the hole, and your good.
Old Oct 2, 2023 | 08:04 PM
senix's Avatar
senix
the ball and the cleats for the chains. All items fit in the holes.
Reese makes and prep kit.
I use curt cleats as they are big and the chain cleats will fit in them easy..
Old Oct 2, 2023 | 08:50 PM
DVR's Avatar
DVR
The "gooseneck hitch kit @ $250" was on my window sticker and included with my truck.
Had it not been, I would have purchased one of the aftermarket kits from etrailer.
Mine is a 2019 so things may have changed.
The "5th wheel hitch prep package" was $500
Old Oct 2, 2023 | 10:01 PM
speakerfritz's Avatar
speakerfritz
I have the prep kit on my 2019 f-450. Two *****, pucks, etc came with it.
but, with 2k pin weight on bumper pull and 20k tow rating on bumper pull….will probally never use the prep kit.
Old Oct 3, 2023 | 01:55 PM
HarveyTruck's Avatar
HarveyTruck
The prep kit also has the additional trailer plug in the bed. I think the prep kit is worth every penny once you figure aftermarket purchase and install. The hitch kit (ball and safety chain cleats) may be just as easy to source aftermarket unless they cost more than the factory kit.
Old Oct 3, 2023 | 02:37 PM
Billn59's Avatar
Billn59
I ordered a 24 with the 5th wheel prep. For a while, I was worried I might have to delete it to get it built because of constraints. I looked at aftermarket and it would cost twice as much minimum. Even looked at DIY but you have to remove the bed to install it and still cost over $500. Luckily, I got a build week and a VIN. Well worth the $500 factory Install.
Old Oct 3, 2023 | 06:20 PM
RadRick's Avatar
RadRick
B&W makes a gooseneck ball with a handle on it, kit comes with the mounting cleats for the safety chains. Weigh Safe makes a gooseneck ball kit with a built in scale that shows how much tongue weight a trailer has.
Old Oct 4, 2023 | 12:36 AM
mavman427's Avatar
mavman427
4wd Low
Ford sells a gooseneck ball and cleats on their website. Purchased mine with my points when I bought my '22. Even had a few bucks leftover for some stake pocket tie downs.
poulton
Oct 28, 2022 07:46 PM
Sbendele
All Things Towing
Jan 19, 2022 06:27 PM
last5oh_302
Jun 8, 2021 11:10 AM
truckzilla 34
Oct 11, 2017 11:10 AM
petei
Jan 4, 2017 01:19 PM
