Fan Belt
Old Sep 28, 2023 | 10:25 AM
RTT's Avatar
RTT
Red face Fan Belt
I think i asked this already , I have a V - grooved looking pulley from fan to alternator with a NOTCHED belt
I am thinking a solid belt belt with no cutout for the notches that are on a notched belt would be sturdier/reliable
Do the notches serve an important purpose I am not seeing ???
I think I have seen more solid belts than notched belts........ ...but I am just a novice........
Old Oct 1, 2023 | 01:02 AM
RTT's Avatar
RTT
While belt & fan off , is there other maintenance items I can/should address
Old Oct 1, 2023 | 07:49 AM
FuzzFace2's Avatar
FuzzFace2
First I dont see what the difference is in the 2 belts they both do the same job just as well so dont worry.
BTW some had the cuts on the outside, others on the inside and some none at all.
Also why was the fan & belt, more so the fan, pulled?
Belt I can see as it was dry, hard & cracked but you should be able to get the belts off & on around the fan by slipping it between the blades.
If the water pump shaft dose not have play and it is not leaking I cant see anything else that needs to be done.
Maybe clean and mark the timing mark for TDC seeing it may be easier to get at it.
Dave ----
Old Oct 1, 2023 | 10:22 AM
tbear853's Avatar
tbear853
In a perfectly straight line pull, a smooth belt might be a hair stronger, but these belts go around corners like "pulleys", and a belt's real strength is built into the unseen inner cords, not the outer rubber friction surface so much. A toothed belt will compress and stretch the outer rubber covering less going around pulleys than a smooth belt will ... and a toothed belt likely runs cooler too. That alternator pulley is a pretty tight turn.
Generally, smooth belts are a little cheaper to buy is my experience.
I don't think the notches are cut, more like molded in.
Does it make a difference .... maybe not, but I've never had a notched or toothed belt fail. I too fish my belts off around the fan blades with no removal. As to water pumps, like said if not leaking and not loose, you have a known good one.
Old Oct 1, 2023 | 11:36 AM
davelj's Avatar
davelj
The belts with inside notches are designed to wrap better around small pulleys like your alternator providing more grip and less slip. The ones with outside notches are a gimmick that is supposed to run cooler. I've never seen any real benefit to them, myself.
Old Oct 2, 2023 | 12:12 PM
RTT's Avatar
RTT
Thank-you all
Several days ago , after no response I did some research & found the notches supposedly helps belt run cooler & more efficiently ( grip better ) .
I took fan off to work on fan shroud .
Belt has small crack at almost every notch , but appears strong . Will replace to be safe
My neighbor replaced his belt on a 76 chevy van & it cost him $32.00 . Scared me ...
My belt looks to b $12.00 or so......... Big relief.......
Old Oct 2, 2023 | 04:58 PM
FuzzFace2's Avatar
FuzzFace2
If the $32 was for just the belt I would say he got ripped off as the 76 van should still have V belts not surp.
Now if that was belt and install then that was way under the $$$ in my book.
I forgot you were fixing the shroud
Dave ----
Old Oct 2, 2023 | 09:44 PM
RTT's Avatar
RTT
My neighbor got taken advantage of . It was just for belt ,no install..........I will get more details & may help him recoup some money - he is elderly........ & gets confused..........
I will look more closely at my belt & pulley cuz I did not see too much V in my belt or pulley , but I was in a hurry as usual......... Pulley looks almost square
Parts store will know....... hopefully............
fre1102
Mar 7, 2024 02:27 AM
Byrd.Dog
Jul 11, 2023 11:36 AM
Martha Neal
1997 - 2003 F150
Jan 5, 2011 07:39 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
16
Jul 18, 2008 08:39 PM
djmac
Jan 28, 2006 01:20 AM
