Swapping info?!?
Old Sep 28, 2023 | 12:07 AM
1956fordguy1967's Avatar
1956fordguy1967
1st Gear
Swapping info?!?
I have 1974 Ford f-100 4x4 with a 360 fe, behind it I believe is a t-18 manual transmission! I want to swap a 302 into there because the 360 is just done and rebuilding it would be just a waste of time aswell the 302 is already to go! I’m just wondering am I going to run into anything that would prevent me from doing this? I know I would have to change the bellhousing, motor mounts, clutch fork etc just wondering is there anything else I should look out for?
Old Sep 28, 2023 | 08:25 AM
uzikaduzi's Avatar
uzikaduzi
i don't know the answer to your question, but if you are swapping out the FE and know you'll have to change a bunch to make the t18 work, why not look for a manual that will bolt right up? prime time to get something with overdrive. the small block version of the zf5 should bolt right up.
Old Sep 28, 2023 | 08:38 AM
tbear853's Avatar
tbear853
Exhaust and any mounts for alternator, power steering, AC, and maybe fan/shroud as required.
bsiebert
18
Jun 23, 2011 05:35 PM
airbusflyboy
Sep 11, 2009 03:13 PM
jestan007
Engine Swaps
Jun 8, 2005 09:25 AM
Frank69for2
Feb 1, 2002 05:13 PM
