PLEASE HELP!!!!2020 super duty codes
Old Sep 27, 2023 | 11:40 AM
cnote1115's Avatar
cnote1115
4wd Low
2020 Ford Super duty 6.7 none of the steering wheel controls work, when you turn the 4wd **** nothing lights up led headlights flicker. I just changed batteries as one was bad. Please help.
Old Sep 27, 2023 | 01:22 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Have you cleared the DTC’s ?
Also when you load your truck in ForScan do not load any saved profile, then check DTC again
ZooDad
Old Sep 27, 2023 | 01:36 PM
cnote1115's Avatar
cnote1115
4wd Low
Yes I cleared them they all came back.
Old Sep 27, 2023 | 02:16 PM
DSLTRK60's Avatar
DSLTRK60
Check powers and grounds. Start there.
Old Sep 27, 2023 | 05:37 PM
cnote1115's Avatar
cnote1115
4wd Low
Been all around the truck. I found this underneath the passenger side door. It’s a ground but it’s cut and I don’t see where it could connect. Any idea?
Old Sep 28, 2023 | 11:59 AM
cnote1115's Avatar
cnote1115
4wd Low
Could the cab to frame ground cause these issues ???
Old Sep 28, 2023 | 12:20 PM
DSLTRK60's Avatar
DSLTRK60
Possibly, but there should be a ground in the BCM harness.
Old Sep 28, 2023 | 01:39 PM
cnote1115's Avatar
cnote1115
4wd Low
Replaced the cab to body ground still same codes. Could the BCM be bad ?
Old Sep 28, 2023 | 09:41 PM
DSLTRK60's Avatar
DSLTRK60
You need to get the module connectors pinout diagram and check powers and grounds there. If those are good, then you will need at least an o scope to make sure the modules are communicating with each other, will usually be the twisted pair of wires from the connector.
Checking powers and grounds is the cheapest method that finds most issues and doesn't require any special tools other than a volt meter.
Last thing you want to do is be buying expensive modules and wasting time and money to find yourself back at square one!
Old Sep 28, 2023 | 09:43 PM
DSLTRK60's Avatar
DSLTRK60
Also, the failures you describe are unclear, are you saying the headlights are fine, THEN when you try the 4x4 **** they flicker?
Do you have any led lights on steering wheel buttons?
Does the dash dimming work?
Old Sep 28, 2023 | 10:20 PM
cnote1115's Avatar
cnote1115
4wd Low
Led headlights flash/strobe low beam and DRL are not working .No steering wheel controls beside horn.IF i move the turn signal stalk in the first 3 seconds after pushing the push to start to acc it will work but I can’t turn it off unless i turn off the truck.The 4wd **** does not turn on the 4h or 4l on the dash.Dimming works ,radio and sun roof work.Runs perfect other than these issues.
Old Sep 28, 2023 | 10:48 PM
4wd6.7L's Avatar
4wd6.7L
Did you put eyes on the BCM? There is a ground lug in the same general location as the BCM too (behind passenger kick panel). Some have had water intrusion that has leaked onto the BCM fouling things up.
Old Sep 29, 2023 | 05:06 AM
number9xd's Avatar
number9xd
Made any recent changes with Forscan?
If so, do you make backups before / after you make changes?
Old Sep 29, 2023 | 05:47 AM
cnote1115's Avatar
cnote1115
4wd Low
No I haven’t changed anything in FORScan
Old Sep 29, 2023 | 10:04 AM
DSLTRK60's Avatar
DSLTRK60
Okay that helps. I strongly think something is wrong with the SCCM(Steering Column Control Module). It's in the housing that holds the wiper and signal stem and it fits around the column behind the plastic covers.
All those failures are commanded by the SCCM specifically.
You still need to find a pinout and wire diagram so you can check the basic power ground integrity and look for chaffed or twisted wires.
Good luck on this.
