2006 timing issue
Old Sep 25, 2023 | 08:24 AM
msscran's Avatar
msscran
3rd Gear
2006 timing issue
I have a 2006 f150 with the 5.4l my old motor with 177000 miles on it died do to lack of oil pressure. I found a new motor for it it was a ford factory rebuilt motor built in 2016 , It only had 30000 miles on it with paperwork from a crashed truck. i put it in my truck. And it runs like crap. It ides fine when you first start it up, Touch the gas goes in to open loop and dies or starts to stall when driving it i can't get over 35mph. When I hook up forscan and look at the cams timing it shows bank 1 running at 0* plus or minus a few. Bank 2 shows it's fully retarted 40* like its not getting oil. I've swapped cam phasers and cleaned both screens and swapped out vct solenoid . Still no luck. I haven't pulled the cam caps yet. I'm thinking the oil passage in the vct solenoid housing could be plugged or a passage in the head. you know one of the 4 holes. It's strange the bank 1 has oil pressure to work and not bank2 thats closest to the oil pump. I have a oil gage in the truck and it says 45-60 psi at the filter area. Does anyone have any ideas for me Thanks for the help
Codes
P0175 code is a generic OBD-II Diagnostic Trouble Code (DTC) defined as System Too Rich (Bank 2). It shows up when the Engine Control Module (ECM) or Powertrain Control Module (PCM) detects too much fuel or insufficient oxygen in the air fuel ratio.
P0022 is logged when the PCM perceives an over-retarded or over delayed timing condition in Bank 2 of the intake camshaft. The crankshaft and camshaft position sensors relay information to the PCM. The module uses the data to determine whether the engine is timed properly by comparing the input from both sensors.
Old Oct 3, 2023 | 09:31 PM
73FOMO's Avatar
73FOMO
Codes
I would go through with entire timing job and replace oil pump with high flow pump while in there. Good chance you have a leaking tensioner seal bleeding off pressure on the one bank that is retarded.
alwaysFlOoReD
2004 - 2008 F150
17
Jul 29, 2024 06:05 PM
grantjp
May 14, 2023 04:08 PM
Creb19
2004 - 2008 F150
Jun 3, 2018 08:21 AM
BStreett
2004 - 2008 F150
Oct 21, 2011 07:05 PM
bigbadford78
May 8, 2005 01:55 PM
