Sponsored by: Real Truck
Leak....I am CLUELESS
Old Sep 26, 2023 | 02:46 PM
karenkarl's Avatar
karenkarl
4wd Low
Stay tuned.....We are going to try to wait and go to our regular mechanic, end of October
Old Sep 27, 2023 | 07:42 PM
redford's Avatar
redford
FTE Leadership Emeritus
You might also post the question about the leak on the 7.3L Power Stroke engine forum.
https://www.ford-trucks.com/forums/forum31/
Old Sep 28, 2023 | 07:57 AM
'65Ford's Avatar
'65Ford
If you ain't driving a ton of miles, might just keep an eye on the fluid levels and wait until your preferred mechanic can look at it. Based on location it's likely engine oil.
A trusted mechanic is worth gold so if it ain't all over your rear axle yet, it may not be so bad that it can't wait a month.
Old Sep 28, 2023 | 12:49 PM
karenkarl's Avatar
karenkarl
4wd Low
The leaking fluid appears to be diesel. Hopefully the truck won't explode? 🙀 The drive to the mechanic is about 25 or so miles.....
Old Sep 28, 2023 | 02:02 PM
WWR's Avatar
WWR
Diesel is relatively difficult to ignite, unlike gas
Old Sep 28, 2023 | 02:23 PM
hobohilton's Avatar
hobohilton
_________________________
I read every reply. I vote this as the best # 1 reply. Check levels frequently and just park it where it won't leave a mess.
Waiting on a trusted mechanic is words of wisdom.
For those that are not in the WEST... Hauling water is a priority.
Old Sep 28, 2023 | 03:02 PM
karenkarl's Avatar
karenkarl
4wd Low
Old Sep 29, 2023 | 12:28 AM
Project78f1504x4's Avatar
Project78f1504x4
https://www.ford-trucks.com/forums/1...-3-motors.html
This link will give you some info on the fuel leak locations. Also where to get o-rings,etc. if you would like to do the work yourself. Rebuilding the fuel bowl and replacing orings/sleeves on fuel lines is simple, just time consuming. Good luck.
Old Sep 29, 2023 | 12:46 AM
karenkarl's Avatar
karenkarl
4wd Low
Thanks for that info but I think I will wait for the mechanic to fix it. The "work-challenged" mechanics who looked at it earlier said there was a leak in the fuel return line and a few other places. I'm an OK bicycle mechanic and a tiny bit of a motorcycle mechanic, but that's it !
Old Sep 29, 2023 | 08:04 AM
WWR's Avatar
WWR
I reco a topside creeper for that kinda work!!
Old Nov 2, 2023 | 10:24 AM
karenkarl's Avatar
karenkarl
4wd Low
Thumbs up Truck is Fixed !
The leak was in the water/fuel separator.
Old Nov 2, 2023 | 10:45 AM
Pickupmanx2's Avatar
Pickupmanx2
Not sure what it ran you to get fixed... but if you can turn a wrench on a m/cycle, you can figure out issues on a truck 👍 will save you some $$ over time fixin the little things.
Old Nov 2, 2023 | 02:20 PM
  #28
karenkarl's Avatar
karenkarl
4wd Low
Trucks are waaay more complicated than old, bomb-proof dirt bikes 😵‍💫
Bananasfoster
Sep 20, 2023 11:11 AM
SuperDutyScaler
May 9, 2023 09:52 AM
Federico385
Apr 8, 2022 05:29 AM
Myyke
Feb 5, 2016 11:36 PM
jaycenk
Jun 29, 2012 09:39 AM
