Speedo drive gear ball bearing size
Old 09-22-2023, 07:46 PM
jwitty's Avatar
jwitty
jwitty is offline
Does anyone know the size of the ball bearing that is used as a key for the speedo gear on the transfer case shaft for a 1990 f250?
Old 09-23-2023, 09:40 AM
manicmechanic007's Avatar
manicmechanic007
manicmechanic007 is online now
Received 1,102 Likes on 1,003 Posts
Not exactly sure but I would think the ball might be the same as a steering gear control valve uses
3/16 maybe
I have a bunch of small ones I save for the grandkids wrist rockets
I think 1/4 is too big
If you measure the hole diameter in the main shaft, the steelie will be just a bit bigger
I will try to find out exactly for you (if it is in an old manual)
wolfking
06-06-2011 08:04 PM
14psd
01-24-2011 09:44 PM
FordBronco88
1978 - 1996 Big Bronco
01-27-2010 05:30 PM
blupton
02-15-2007 07:20 PM
rogerelaw
03-14-2001 10:37 PM
Quick Reply: Speedo drive gear ball bearing size
