Building up the 351m
Old Sep 22, 2023 | 06:12 PM
BluJim's Avatar
BluJim
3rd Gear
Hello, I'm currently building or rebuilding, I should say, the 351m that is in my 78 F150 4x4 that I found back after being sold in 82! I want to return the truck to its former newness on the outside but a little more punch on the inside. It's been bored over .040, I've installed new rings after honing the cylinders. Dave McClain checked the block out and installed new cam bearing and freeze plugs. I have a new timing gear setup along with headers, performer 400 intake, and a Holley 600cfm coming. I'm stuck between cams right now. I want a nice smooth idle with good low end performance and mileage. The truck won't be driven daily nor abused offroad. I don't plan on towing anything either, just a truck that has more pep and drive ability. I like the Melling with.204 lift and 107 lobe separation. I believe its in a pkg mtf-2 with lifters. Any suggestions are appreciated. Thanks.
Old Sep 22, 2023 | 07:19 PM
cb_13's Avatar
cb_13
Personally I’d ask McClain’s what they suggest for your intended usage and use that. That’s exactly what my brother in law did with a couple of 460s and he was VERY pleased with the results.
We’re lucky to have such a knowledgeable Ford engine builder in our rural area.
Old Sep 22, 2023 | 07:26 PM
BluJim's Avatar
BluJim
3rd Gear
Thanks cb,
I've talked to him recently and planning seeing him at his shop to follow up and get some numbers down. Thanks
Old Sep 22, 2023 | 07:52 PM
Mark8man's Avatar
Mark8man
Sounds good. Please keep us posted what you decide on and the eventual road test report.
Old Sep 22, 2023 | 09:31 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I agree ask Dave. And here is some old info, but still good info on the 351M.
https://www.ford-trucks.com/forums/1...l#post18718464
All torque specs for 351M and 400.
Camshaft sprocket bolt--------40-45 ft.lbs.
Camshaft thrust plate bolts---9-12 ft. lbs.
Crankshaft damper bolt--------70-90 ft. lbs.
Crank pulley bolts------------35-50 ft. lbs.
Cylinder head bolts---------step one--75 ft. lbs, step two--95-105 ft. lbs.
Distributor hold down bolt---20 ft. lbs.
Exhaust manifolds------------18-24 ft. lbs.
Fuel pump to engine----bolt 10-15 ft. lbs.-----nut- 14-20 ft. lbs.
Intake manifold bolts--------3/8 in. bolt--22-32 ft. lbs, 5/16 in. bolt-19-25 ft. lbs.
Main bearing cap bolts--------70-90 ft. lbs.
Oil pan bolts--------------7-9 ft. lbs.
Oil pan plug--------------15-25 ft. lbs.
Oil pump bolts-----------22-32 ft. lbs.
Fan to water pump bolts---12-18 ft. lbs.
Rocker arm cover bolts-------3-5 ft. lbs.
Rocker arm stud/bolt--------18-25 ft. lbs.
Rod bearing cap nuts--------40-45 ft. lbs.
Spark plugs----------------10-15 ft. lbs.
Starter mounting bolts----15-20 ft. lbs.
Timing cover bolts--------12-18 ft. lbs.
Water pump to engine------12-18 ft. lbs.
And the firing order for the 351C, 351M, 400 is 1-3-7-2-6-5-4-8
Old Sep 23, 2023 | 10:09 AM
LandAndStone's Avatar
LandAndStone
Desk Jockey
Following. Same project in the queue.
balingwire
Oct 27, 2021 05:29 PM
Stephen Comer
22
Sep 15, 2021 06:47 PM
derbydad276
May 25, 2015 06:05 AM
wyazel1
Jul 19, 2008 11:55 PM
nutinbutford
Oct 1, 2006 03:14 AM
