Help please
Old Sep 20, 2023 | 07:44 PM
Toolmantrucker's Avatar
Toolmantrucker
8th Gear
Help please
I have a 97 f350 4x4 4 door srw long bed. It will run like new with plenty of power when cold in cold weather. Once it warms up it lacks power. Summer time it lacks power also. Even if the engine is cool.
Old Sep 20, 2023 | 08:07 PM
97-psd's Avatar
97-psd
Welcome to FTE. Sounds like this has been an on gong problem. Have you done anything in an attempt to correct it? Can you data log the truck?
Old Sep 20, 2023 | 09:55 PM
Toolmantrucker
8th Gear
I’ve changed a lot. Only thing I haven’t changed was the transmission range sensor, and the turbo.
Old Sep 20, 2023 | 10:45 PM
fordman67's Avatar
fordman67
Is your fuel filter black or anything darker than the nice tan it should be and do you have a way to monitor ipr duty cycle and icp pressure?
Old Sep 20, 2023 | 11:10 PM
Toolmantrucker
8th Gear
It’s black when I change it yes. Yes I can monitor it.
Icp says around 600psi at idle
Old Sep 21, 2023 | 06:26 AM
knottyrope's Avatar
knottyrope
What is IPR % duty cycle cold and hot at idle and 3k rpm?
If there is a big difference then orings on injectors are leaking.
Black fuel filter can mean bad orings on injectors too or algae growing in fuel tank.
If cold water put on IPR when engine is hot and power comes back for bit, then IPR could be suspect.
Old Sep 21, 2023 | 07:51 AM
Toolmantrucker
8th Gear
Yesterday when engine was hot and at idle it was 6.25% for ipr I’ll check it on lunch for the 3k rpm.
Old Oct 3, 2023 | 05:36 PM
Toolmantrucker
8th Gear
Icp seems normal. It goes from 600 to 3k
ipr however runs around 10-14 and only get up to 24-27 duty cycle.
Old Oct 3, 2023 | 07:16 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
How many miles on factory AA injectors?
Old Oct 3, 2023 | 07:27 PM
Toolmantrucker
8th Gear
I’m the 3rd owner. Truck has 246k miles. Bought with 202k. Been same problem from the start.
Old Oct 4, 2023 | 07:57 AM
Bitterroot Diesel
Former Vendor
Do you have a Hydra chip? I'm wondering if the cold weather fuel map is making up for the under performing injectors.
Old Oct 4, 2023 | 08:01 AM
Toolmantrucker
8th Gear
No, it’s all stock. No chips installed
Old Oct 4, 2023 | 09:34 AM
knottyrope's Avatar
knottyrope
IIRC IPR should reach 34% at max throttle.
Its possible the PCM has a program from a tuner prior
Can you look at the PCM and see if there is a chip on it?
Old Oct 4, 2023 | 06:01 PM
Toolmantrucker
8th Gear
I just checked no chip on the pcm.
Old Oct 5, 2023 | 09:00 AM
knottyrope's Avatar
knottyrope
possible it was flashed and then chip removed
Might be worth having the PCM checked out
