Voltage gauge going haywire
Old Sep 20, 2023 | 01:22 PM
Firs's Avatar
Firs
Hey y’all, I am stumped. I’m not that good with the whole electrical side of my truck and it shows. Anyway, my voltage gauge is going haywire. It goes from 8 volts to 16 super fast. It’s like it waving to me. It just started as I was cruising down the highway. 70 miles per hour, 2k rpm. I’ve got a 1995 f250 4.9l automatic.
Any info is much appreciated. Thanks!
Old Sep 20, 2023 | 03:30 PM
OhioFordFarm's Avatar
OhioFordFarm
first thing I would do I check voltage with a after market gauge, or better a good volt meter ( VOM tester ) and find out if your gauge is going bad, or problems with electrical system.
Old Sep 20, 2023 | 03:35 PM
Firs's Avatar
Firs
I think I can be sure that the voltage is bad because when I went low my dash lights would go dim and my stereo shut off and my turn signals would slow down.
Old Sep 20, 2023 | 03:40 PM
OhioFordFarm
Voltage regulator issues, or ALT going bad? loose, poor battery or battery connections.
Advanced Auto Parts and a few others can do a charging system test. This might point you in the correct direction if unsure.
Check cables, and connections first. Ford trucks have a real problem with the ground cable going to the motor. poor grounds can make for major hard to find problems.
Old Sep 20, 2023 | 03:55 PM
Firs's Avatar
Firs
I should definitely check the grounds. I just replaced the engine and had to undo lots of grounds so maybe ones of them is not quite right.
joezzz
Jul 5, 2021 05:01 PM
Amish65F100
Apr 15, 2017 09:38 PM
olemoffat
Apr 6, 2014 11:40 PM
lewis racing
Sep 19, 2010 06:30 PM
87wreckerman
Nov 9, 2008 02:34 PM
