Vacuum Pump
Old Sep 19, 2023 | 07:12 PM
CJMOStang's Avatar
CJMOStang
Vacuum Pump
When I rebuilt my 8BA I added a PCV valve which takes up my carb vacuum line. Now that I’ve added a vacuum boosted master cylinder, I decided to add a vacuum pump and relay but of course I have no diagram.
Can anyone educate me on relays and help me wire it? I have a one wire switch, two wire pump and a 4 wire relay with terminals for 85-86-87-30
Old Sep 19, 2023 | 09:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The vacuum connection on most 8BA/8RT engines for the wipers is inadequate for power brakes. Big-truck manifolds had a separate connection with much larger capacity specifically for power brakes, see picture below (plugged connection). I think you'd be better off using manifold vacuum for the PB's than a pump.
Old Sep 19, 2023 | 09:31 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Just swap "Light" for "Vacuum Pump" and add an appropriate fuse between the battery and 30.
I use the manifold vacuum as @ALBUQ F-1 stated for my stock vacuum boosters and power clutch.
Old Sep 20, 2023 | 09:54 AM
52 Merc's Avatar
52 Merc
It wouldn't be difficult to drill and tap the back of the manifold to add the brake nipple. Easier than mounting pumps and running wires, and be more efficient.
Old Sep 20, 2023 | 10:13 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It is actually not that easy to drill, first because of the size of the main threads, second because two holes need to be drilled at an angle from the main bore into the throttle bores. For sure you'd want to have the manifold off because of shavings, but also to be able to jig it up in a drill press. Getting a different manifold that has the tap would be cheaper except for the shipping. But it's a golden opportunity to get an aluminum manifold at the same time.
Old Sep 20, 2023 | 01:51 PM
big job's Avatar
big job
If me I would go for a belt driven vac pump like Power stroke diesels they are small in size.
Old Sep 23, 2023 | 08:50 AM
FuzzFace2's Avatar
FuzzFace2
I am not up on the PS diesel's but are you sure that belt driven pump is not power steering and the brakes are Hydro Boost.
I had a 86 Chevy K5 full size Blazer with the 6.2 diesel and the power brakes were Hydro Boost run off the power steering pump.
It was not fun when the booster pump seal let go and pumped all the steering fluid inside and soaked the rug
BTW the 6.2 did have a vacuum pump for HVAC but it was in the place where a dist. would have been installed if it was a gas motor.
It worked like SH**
Dave ----
Old Sep 24, 2023 | 05:26 AM
Marten's Avatar
Marten
What brand of vacuum pump do you have.? Are you sure it needs a relay. I just put a new one on my truck. All it needed was power and ground.
I agree with FuzzFace2, that sounds like a hydroboost on the diesel truck if it is belt driven.
Old Sep 24, 2023 | 11:10 AM
bmoran4's Avatar
bmoran4
A relay is almost always a good option as it separates control and load circuits. Also, don't neglect to strategically include fuses/breakers.
Old Sep 25, 2023 | 05:42 AM
Marten's Avatar
Marten
I went with Leed brakes vacuum pump system. It is an all in one unit. Probably has the relay built inside the case.
Old Sep 25, 2023 | 06:21 AM
bmoran4's Avatar
bmoran4
The Leed System Installation instructions call out an inline fuse, which is great. It also states that it requires 15 Amps of switched power, a seemingly perfect use of a relay. There is no relay internal to the unit; that is impossible with the only power and ground wires the unit has.
Old Sep 25, 2023 | 07:32 PM
Marten's Avatar
Marten
It's a world beyond me. I know that I bought a black bandit system from Leed systems and installed it. Had an inline fuse that I cut out because I had a 15 amp fused circuit from my panel. The other wire I ran to ground. Everything else is inside the "can". I did not open it up. But I know that my brakes have been amazing since I put this on and junked the old brake booster that my mechanic put on and charged my outrages money for. Perhaps there is a relay inside but at this point I am not opening it up to find out. I know it works and I am super happy with it.
Anthony Jenkins
Oct 15, 2019 02:55 PM
danlee
Mar 23, 2017 09:27 AM
2002_F-250
Apr 21, 2011 08:20 PM
Bobcat7
Jul 18, 2010 07:22 AM
strokersace
Jan 14, 2010 10:00 AM
