Frame
Old Sep 19, 2023 | 03:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
I'd worry if it was a Ram, but you're driving a Super Duty.
Old Sep 19, 2023 | 03:31 PM
RevRay's Avatar
RevRay
4wd Low
RLOL…that’s why I chose Ford Super Duty !!
Old Sep 19, 2023 | 03:50 PM
willynilly's Avatar
willynilly
Originally Posted by 4wd6.7L
It's been pretty well established that the frame can handle it, but just for fun...some might remember this dramatic stunt Ford did to show off frame strength.
https://youtu.be/mvkz5XY4oTY?si=1Wr7alIJE2AG5HoY
did you see the comments lol. its a sham. the rigging aparatus is the only thing with a load on it . suckers
Old Sep 19, 2023 | 03:56 PM
4wd6.7L's Avatar
4wd6.7L
Nope, didn't read the comments, don't really care one way or another. I am aware it was a dramatic stunt for marketing, not unlike trucks towing trains etc. Still seemed to be appropriate for a thread discussing frame strength. Sham.or not, the frame is plenty strong and can handle being lifted from the reciever.
Was it the RAM comment that got you interested?
Old Sep 19, 2023 | 04:07 PM
willynilly's Avatar
willynilly
i call bs. you seen the comments and knew it was a scam
RevRay's Avatar
RevRay
4wd Low
I did not check the comments either but I would think even the rigging would put my “pressure” on the frame than my jacking on the receiver hitch…lol
Old Sep 19, 2023 | 04:20 PM
willynilly's Avatar
willynilly
ray the rear portion of your truck is likely a bit over 3k. did it bend the frame no. did it bend anything probly not but the hitch isnt the best jacking location
Old Sep 19, 2023 | 04:24 PM
RevRay's Avatar
RevRay
4wd Low
I agree…that’s where I was told to jack and I didn’t really think much about it until AFTER we had done it. Thanks for the insight. On the bright side…the RAS has firmed up my unloaded ride. Seems to be more planted…if that’s possible since it’s a SD.
Old Sep 19, 2023 | 04:55 PM
willynilly's Avatar
willynilly
read the owners manual it will say where good jack points are. probly under the axle at the leaf spring perch.
because your not a mechanic isnt a excuse for ignorance.
Old Sep 19, 2023 | 04:57 PM
Louisville Joe's Avatar
Louisville Joe
Except that the stunt really did not demonstrate frame strength much! Notice the points they suspended the test frame from were in line with the points they pickup up the load of the trucks from?
Good commercial though.
Old Sep 19, 2023 | 07:13 PM
RevRay's Avatar
RevRay
4wd Low
I agree…I definitely need to take time to do that. I have watched some videos as well
Old Sep 19, 2023 | 08:13 PM
morehouse7's Avatar
morehouse7
I do it all the time, sleep easy.
Old Sep 19, 2023 | 08:16 PM
  #28
RevRay's Avatar
RevRay
4wd Low
Thanks…because of this group I will be able too. I didn’t sleep well the last few nights. Didn’t know how to tell my wife I had damaged my new to me truck …lol.
Old Sep 19, 2023 | 10:22 PM
  #29
speakerfritz's Avatar
speakerfritz
Originally Posted by RevRay
I have a 2018 250 Lariat 6.7 4x4 crew cab. I jacked up the rearend yesterday by using a floor jack under my receiver bar in my 2.5 hitch receiver to get my rear wheels off the ground (unload my suspension) to install my RAS. I has the rear wheels about 2 inches off the ground while I did the install. Truck is fine but I have been told I could have bent my frame with the upward pressure at the receiver hitch. I assumed the
receiver hitch would be a strong jack point. Was I wrong? Could I have damaged my frame ?? Thanks
simple match
oin weight on a 3” receiver is 2000lbs
the back of your truck probally weights weighs 4000 lbs
best would be to heck it up fron the axle …I use 2 jacks close to where the axle y bolts are. Not too crazy about jacking it up fron axle pumpkin but folks have done that.
Old Sep 19, 2023 | 10:46 PM
  #30
JayCarver's Avatar
JayCarver
I lift my trucks by the hitch all the time and have been for over 20years. Never a problem. If they can’t handle that I don’t want it.
