460 mounts
Old Sep 17, 2023 | 08:39 AM
Branden Heine's Avatar
Branden Heine
460 mounts
Did ford change the mounting holes on the block or did they remain the same from 73-96? I was told 73-79 ford 460 truck mounts would be a direct bolt on, can anyone confirm that? By the way the engine I’m using is a 460 efi out of a 91 f250 and wasn’t sure if ford changed stuff by then.
Old Sep 18, 2023 | 04:51 AM
manicmechanic007's Avatar
manicmechanic007
Have Autozone pull both mounts and compare the bolt holes
I think they should be the same
Dave would surely know, maybe he will chime in
Old Sep 18, 2023 | 05:45 AM
DaveMcLain's Avatar
DaveMcLain
The block stayed the same from '68 till the end of production. The mounts from the '70's truck look sort of like the ones on a Chevy V8 where a stamped steel piece bolts to the block and then that straddles the rubber mount part that bolts to the frame. My truck has this style of mount and they are a pain.
Old Sep 18, 2023 | 11:58 PM
DB429SCJ's Avatar
DB429SCJ
The 73-79 460 mounts should work, but will only work on 2WD trucks.
Old Oct 9, 2023 | 03:05 PM
KAGAN21's Avatar
KAGAN21
So if I'm reading this right a 460 block (just the block) out of a 73 T-bird should mount to a 97 f250HD right?
Old Oct 9, 2023 | 03:18 PM
DaveMcLain's Avatar
DaveMcLain
Yes. It'll bolt up to the mounts no problem.
Melofton
Sep 11, 2019 01:50 PM
dnkensinger
Feb 24, 2015 06:23 AM
loveless41908
Sep 11, 2014 09:53 PM
F-250 WARHORSE
Aug 28, 2011 03:37 PM
hotboat1
Aug 2, 2002 10:27 AM
