Front End Clicking Noise
Old Aug 20, 2004 | 09:47 PM
Msp541's Avatar
Msp541
Exclamation Front End Clicking Noise
On my 1999 Mountaineer AWD V-8 i have a clicking/thumping noise when driving at a low speed like 20-40 mph, when going over bumps it makes no noise. When turning the wheel it makes no noise either but seem to feel it a little through the steering wheel but comes and goes. I replaced the front brakes & rotors, new lower ball joints, new stabalizer bar bushings and i cant think of what the heck it could be at this point. Im stunned and wanted to know if anyone would have some help with this probelm.
Thanks to all!
Old Aug 21, 2004 | 12:00 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Just a guess, but it might be your inner tie rod ends. Mine had a creaking/popping noise that disappeared when I greased the passenger side inner end. I also had to replace the boot.
Old Aug 21, 2004 | 02:13 PM
Msp541's Avatar
Msp541
Inner tie rods are good i replaced them last year so that isnt it more problems to figure out....... ughhhhhhhhhhhhhhhhhh
Old Aug 22, 2004 | 10:13 PM
showle's Avatar
showle
i got something similar going on i think mine might be cv shafts
Old Aug 23, 2004 | 10:23 PM
showle's Avatar
showle
yep that seems to have gotten it
Old Aug 23, 2004 | 10:28 PM
Msp541's Avatar
Msp541
was it the cv shafts?
Old Aug 23, 2004 | 10:31 PM
showle's Avatar
showle
yes drivers side
Old Aug 23, 2004 | 10:34 PM
Msp541's Avatar
Msp541
did you replace the cv shaft or greased it or something?
Old Aug 23, 2004 | 10:36 PM
showle's Avatar
showle
i replaced it...
Old Aug 23, 2004 | 10:38 PM
Msp541's Avatar
Msp541
is it hard to replace the cv shaft? is it a complete assembly and did u get it from ford?
Old Aug 23, 2004 | 10:51 PM
showle's Avatar
showle
67$ part..45$labor
Old Aug 23, 2004 | 10:53 PM
Msp541's Avatar
Msp541
is that the half shaft? and is the part aftermarket or from ford sorry for the questions.... thanks!
Old Aug 23, 2004 | 10:55 PM
showle's Avatar
showle
yes halfshaft...got it from NAPA
Old Nov 3, 2005 | 03:20 PM
gdm1952's Avatar
gdm1952
What/ how did you lube the inner tie rod ends?
Clamps ??
Thanks
GDM1952
Old Nov 3, 2005 | 08:37 PM
thelonerangerxlt
GDM1952, I removed the boot and pressed grease into the inner tie rod end using my fingers. The job requires some patience since there's not much room to work. I cut the boot bands with nippers, and used zip ties to secure the boot afterwards.
TLR
Bronco Buddy
1978 - 1996 Big Bronco
Dec 16, 2020 12:47 PM
soling2003
6.7L Power Stroke Diesel
Sep 14, 2020 08:12 PM
Grease & Gravel
1983 - 2012 Ranger & B-Series
Mar 24, 2017 09:42 PM
derail01
Feb 2, 2017 11:28 AM
jb3824
Sep 9, 2006 08:47 AM
