1999 e250 energy suspension radius arm bushings
You do need to use or re-use the factory supplied plastic spacers, same orientation as installed using the factory parts. I've talked to Energy Suspension about their included printed installation instructions but they never responded---that was maybe 5 years ago.
Without the spacer the urethane bushings will pull through the frame bracket---it's happened to me.
My mistake, I meant to ask what the difference is between the stock spacer and the aftermarket spacer? I ordered some oem spacers, just waiting for them to arrive. I do have a set of aftermarket black spacers from a previous job, I was just wondering if I could have just used those instead of the oem spacers.
When I decided to re-install the OEM plastic spacers one of mine was broken so just ordered two new parts directly from Ford. I don't think who manufactured the spacers matters as much as having them in place whether using Energy Suspension or OEM bushings.
FWIW here's what happens over time without the OEM spacer and urethane bushings:
Here's the stock parts installed as designed:
I jacked mine really high, dropping the beams down, used ratchet straps, not the safest way to do them.
The following users liked this post:
stevorino
06-17-2013 06:34 AM
Cheap Monster
1978 - 1996 Big Bronco
05-09-2002 12:54 AM
big60
08-02-2001 09:02 AM
