Sponsored by: Real Truck
Brake caliper rubbing
Old Sep 11, 2023 | 08:19 PM
Teaspoon2's Avatar
Teaspoon2
2nd Gear
Replaced pads on both sides
passenger side is now rubbing the rim
Tried 2nd set of pads also
Old Sep 12, 2023 | 06:35 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Sounds like something didn't get put back together properly. What part is rubbing the rim, because this shouldn't be able to happen with stock rims. IF you have aftermarket rims then all bets are off, someone could have purchased rims with an incorrect offset and you'll need to get rims with the correct offset.
Old Sep 12, 2023 | 08:47 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Detailed photos (several) would help greatly.
Also...
Details of truck. There are way too many to be guessing about which one you have.
Old Sep 12, 2023 | 09:02 AM
Teaspoon2's Avatar
Teaspoon2
2nd Gear
Stock rims just changed pads Turned wrenches for 35 years
Old Sep 12, 2023 | 10:45 AM
99powerstrokedF250
If everything is stock and was replaced with stock parts, then it shouldn't rub. It should have a good half-inch or better of clearance depending on your stock rim size. My '99, 2003, and 2004 all had 16" rims, I did MANY brake jobs and never had the calipers rub.
From that picture I see coil springs, which means '05+. Your rims should be NO SMALLER than 16", more likely 17".
Again, either something wasn't put together correctly/torqued properly, or you have incorrect components in the system. Given that everything looks rusty I'd say you have stock parts.
Show us a straight-on view looking at the hub/brakes. Something doesn't look right about the pad/caliper mounting bracket.
Old Sep 12, 2023 | 05:31 PM
nydiver's Avatar
nydiver
Have to agree, with new pads it moves the caliper a bit farther out and with 16" rims from a early SD on they would now rub.
Old Sep 14, 2023 | 12:35 PM
OneTon350's Avatar
OneTon350
My guess would be that the square headed flange on the bolt isn't
seated properly and causing a tilt in the caliber. That's really weird.
cuccs58
Oct 7, 2014 07:32 PM
Vinford
Nov 19, 2012 06:36 PM
cooktc2012
2004 - 2008 F150
Oct 6, 2012 09:17 AM
kurtdirt
1997 - 2003 F150
Mar 17, 2008 06:13 PM
MrValentine
May 14, 2004 07:57 PM
