Sponsored by: Auxito
rims
Old Mar 17, 2008 | 04:41 PM
kurtdirt's Avatar
kurtdirt
rims
i own a 2003 f150 with 16in. rims but i own a sweet set of 15in. rims. is there anyway that i can put them on? maybe adapters??
Old Mar 17, 2008 | 04:55 PM
Bobby82490's Avatar
Bobby82490
Nope, they will hit the brake components.
Old Mar 17, 2008 | 04:58 PM
kurtdirt's Avatar
kurtdirt
even if i grind the calipers??
Old Mar 17, 2008 | 05:05 PM
97Handshaker's Avatar
97Handshaker
i dont know, are they a 5X135 bolt pattern?
Old Mar 17, 2008 | 05:07 PM
kurtdirt's Avatar
kurtdirt
yes they are
Old Mar 17, 2008 | 05:13 PM
Bobby82490's Avatar
Bobby82490
I will show you one of the posts i posted here when i first started here. This post was from back when i didnt know much about trucks, now that i have hung out on this forum i have learned alot.
https://www.ford-trucks.com/forums/s...6&goto=newpost
Old Mar 17, 2008 | 05:15 PM
Bobby82490's Avatar
Bobby82490
Well if they are a 5x135mm pattern, you could always try them, but im almost certain they wouldnt fit. Also, what vehicle did you have them for, since these f-150 are the only vehicles that have a 5x135mm pattern?
Old Mar 17, 2008 | 05:31 PM
kurtdirt's Avatar
kurtdirt
the rims where on my 91 f150 (the project truck)
Old Mar 17, 2008 | 05:35 PM
Bobby82490's Avatar
Bobby82490
well then they are like 5x5 or 5x5.5, only the 97+ 1/2 tons had the 5x135 pattern.
So unless you swapped out the drivetrain, then the bolt pattern isnt 5x135mm.
Old Mar 17, 2008 | 06:13 PM
kurtdirt's Avatar
kurtdirt
i will double check the pattern but thats what they told me it was when i bought them.
