Transmission issues, 4spd AOD, HELP!
there should be a cable running from the throttle linkage on the carburetor down to the side of the transmission. This is called the TV cable and is absolutely critical to the life of the transmission. If it's unhooked or broken or missing, or even misadjusted, the transmission won't last A trip around the block.
If it's not absolutely stuck, (like on 4 flat tires with the brakes locked up) i'd say it's time to pull the transmission.
I had an AOD rebuilt about three years ago and it was $1500. I wouldn't be surprised if it's over 2000 now. If this isn't within your budget, you can look for a used one to swap in, but that's a gamble that could just put you deeper in the hole. A C4 or C6 would also bolt in place of the AOD, with minor changes. You'd lose overdrive, but it would get you on the road if that's what you can find.
if you've got the gumption, it is possible to rebuild it by yourself at home, but it's not for the faint of heart or inexperienced. And it's easy to get in over your head. So don't recommend trying it unless you know your skills are good enough and you're confident in your ability. (And you have the speciality tools) not many people are this good.
Adjustment At The Carburetor
TV control linkage may be adjusted at the carburetor using the following procedure:
- Check that engine idle speed is set at the specification.
- De-cam the fast idle cam on the carburetor so that the throttle lever is at its idle stop. Place shift lever in N (neutral), set park brake (engine off).
- Back out linkage lever adjusting screw all the way (screw end if flush with lever face).
- Turn in adjusting screw until a thin shim (0.005 inch; max.) or piece of writing paper fits snugly between end of screw and Throttle Lever. To eliminate effect of friction, push linkage lever forward (tending to close gap) and release before checking clearance between end of screw and throttle lever. Do not apply any load on levers with tools or hands while checking gap.
- Turn in adjusting screw an additional four turns. (Four turns are preferred. Two turns minimum is permissible if screw travel is limited).
- If it is not possible to turn in adjusting screw at least two addition turns or if there was sufficient screw adjusting capacity to obtain an initial gap in Step 2 above, refer to Linkage Adjustment at Transmission.Whenever it is required to adjust idle speed by more than 50 rpm, the adjustment screw on the linkage lever at the carburetor should also be readjusted as shown.
Idle Speed Change/Turns on Linkage Lever Adjustment Screw
- Less than 50 rpm: No change required
- 50 to 100 rpm increase: 11/2 turns out
- 50 to 100 rpm decrease: 11/2 turns in
- 100 to 150 rpm increase: 21/2 turns out
- 100 to 150 rpm decrease: 21/2 turns in
After making any idle speed adjustments, always verify the linkage lever and throttle lever are in contact with the throttle lever at its idle stop and the shift lever is in N (neutral).
Adjustment At Transmission
Automatic overdrive transmission linkage adjustment
The linkage lever adjustment screw has limited adjustment capability. It is not possible to adjust the TV linkage using this screw, the length of the TV control rod assembly must be readjusted using the following procedure. This procedure must also be followed whenever a new TV control rod assembly is installed.This procedure requires placing the vehicle on jackstands to give access to the linkage components at the transmission TV control lever.
- Set the engine curb idle speed to specification.
- With engine off, de-cam the fast idle cam on the carburetor so that the throttle lever is against the idle stop. Place shift lever in Neutral and set park brake (engine off).
- Set the linkage lever adjustment screw at its approximately mid-range.
- If a new TV control rod assembly is being installed, connect the rod to the linkage lever at the carburetor.
The following steps involve working in proximity to the exhaust system. Allow the exhaust system to cool before proceeding.
- Raise the vehicle on the hoist.
- Using a 13mm box end wrench, loosen the bolt on the sliding trunnion block on the TV control rod assembly. Remove any corrosion from the control rod and free-up the trunnion block so that it slides freely on the control rod. Insert pin into transmission lever grommet.
- Push up on the lower end of the control rod to insure that the linkage lever at carburetor is firmly against the throttle lever. Release force on rod. Rod must stay up.
- Push the TV control lever on the transmission up against its internal stop with a firm force (approximately 5 pounds) and tighten the bolt on the trunnion block. do not relax force on lever until nut is tightened.
- Lower the vehicle and verify that the throttle lever is still against the idle stop. If not, repeat steps 2 through 9.
